Question about Uniden Cordless Phone
Adding additional uniden phones
We have a uniden answering machine that came with 3 phones, the phone at the anwering machine and 2 other remote phones. We recently bought two more uniden phones to replace older phones we had in additional rooms. We cannot get the new phones to work. What have we forgotten to do? Thanks BOBO6
  • 385 Answers
Register them to the base,
Your manual should show you how.
Hope this helps
Regards.
Posted on Apr 19, 2009
Uniden cordless 6.0 answering machine , reset code on security code answering machine?
To reset the Security Code for remote access into the
answering machine system ( model D1680 & similar )
1 press [menu]
2. scroll to "Ans. Setup" press [select]
3. scroll to "Ans. Setup / Security Code" press [select]
4. first digit will be blinking, enter two digits of your choice
5. press [select]
6. press [END] to conclude & exit
Apr 11, 2015 | Uniden DECT 6.0 Cordless Phone ID
I have a uniden dect 6.0 corless phone with anwering machine. I can't figure out how to record a new outgoing message
Specify the model of your answering machine from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Apr 21, 2011 | Uniden DECT 6.0 Cordless Phone
"i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Apr 13, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden PowerMax 5.8 no audio transmission on two of three remotes
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Adding speed dial nos to uniden waterproof handset
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Jun 19, 2008 | Uniden Tru-Digital Expansion Waterproof...
Model 26990GE1-D
how do i change the anwering machine from spanish to english?
Jan 22, 2008 | Uniden Cordless Phone
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Oct 23, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden Cordless Phone Logo
111 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
