Question about D-Link DI 713p (DI-713P) Wireless Router
Wanting wireless hookup
I live in the country where I can only have Localnet dial up. I have a home computer,but want to use my laptop also at the same time.How do I get the stuff that will work?
  • 2 more comments
  • d_s_a_blackl Dec 02, 2008
    I live in the country,and only have localnet dial up.But want to use my laptop at the same time.I need to know what all I need to hook up to a wireless routor or whatever else that I may need
    Well it looks like I'm going to get anywhere here.Doesn't look I'm going to be able to do anything.So you might as well give me my REFUND back.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The simplest would be:
  • run the home computer as it is, connected to the Internet through dialup;
  • in the home computer, enable Internet Connection Sharing;
  • purchase a crossover Ethernet cable;
  • plug the crossover Ehternet cable from the home computer to the laptop.
If you want more details or a step by step, post back;
  • Operating Systems of the home computer and the laptop;
  • is the laptop WiFi capable and do you want to use it;
  • are you planning to use DSL if and when available and/or add PCs later.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 02, 2008
  • 4,806 Answers
Ok, I don't know if you have just a normal ADSL modem or a wireles ADSL modem router (the wire from the phone point will connect to one of these) If the router is wireless and your laptop supports wireless, then we need to know which of these you have.
Please give a detailed description so we can help you further.
regards
  • Lee Hodgson
    Lee Hodgson Dec 02, 2008
    and we need your laptops make and model.......
    Sergeant:
  • 217 Answers
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork Wanting wireless hookup - clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
  • Tianen Kinchelow Oct 05, 2011
    modem is connected to wirless router, but still no wifi. how do you know if you have wifi. had tablet that wouldn't get connected,didn't receive my wifi connection. have belkin router and comcast connection which is not wirless old wall connetion,could this make a difference?
  • 3,037 Answers
What you need to do is run the dial-up to your desktop. Then have a router that you run a Cat 5 cable from your desktop to it. Then run a cable from the router to your laptop and then configure your desktop and laptop settings to set up a network under Start>Control Panel>Connections
If you have any specific questions while doing this, please let me know
  • 162 Answers
Here's my take:
internet -> dial-up modem -> desktop (share the connection) -> router -> other computer (wired or WIRELESS)
note: must turn OFF DHCP on router and set manual IP to it and to the other computer
  • 1,879 Answers
2 ways to do that
get a router with a dial-up feature like the SMC 7004BR broadband Barricade router with dialup fallback.
or
make your home computer (desktop?) share the internet connection. you need a small hub to connect both computers to create a home network. have the desktop use the modem, connect to ISP, then launch the Network Setup Wizard.
  • monk3ybidzness
    monk3ybidzness Dec 02, 2008
    omit the "small hub" requirement as you already have a Dlink router (will act as a hub)
    tried searching for an external dial-up modem with ethernet port for your dlink router connection, it's either it doesn't exist or are as rare as hen's teeth.
    Master:
  • 474 Answers
Well if your using dial up it may be more trouble than its wrorth. Generally, Wireless routers use network or Patch cables and connect to a High speed modem. if you want to use dial up, you would have to get a dial up wirless modem, which are probably hard to find now a days, at a local store. You could get a port splitter and install the dial up software on the laptop and wire it directly in just like the pc is, into the phone jack, but you can only have one at a time using the dial up or you will get data colisions like when some one calls and it kicks you off.
One otehr option is to get a Mode that connects through the phone line, like AT&T used to do, then, from the Modem you plug a Wirless router into it. Configure the router so that your laptop can connact wirelessly, try to connect you computer with a hard wire if you can or get a wirless card for it.
So then basically you have a small home network that goes through a modem that goes through the phone line.
For this you would have to have a service provider though that covers your Area. I would call them all, compare prices and see whats available.
As far as hardware, routers and modems can be found at walmart or any computer store.
Good luck
MajicJack Plus is dialing random phone numbers around the country, when no one at home is dialing.
This sounds like a problem that MagicJack support can troubleshoot for you. I have a MagicJack, and I do not have these problems.
You didn't say whether you have your MagicJack device plugged into your computer, or whether (like me) you have your MagicJack connected to your home network directly with just an Ethernet cable.
If you have your MagicJack plugged into a USB port on your computer, there is a possibility that some program installed on your computer is dialing the phone numbers Such a program would almost certainly be malware that you want to remove.
If you do not have an anti-malware program installed on your computer, you should get one immediately. There are quite a few free anti-malware programs, like Avast or AVG, that you can install to help protect your computer from malware.
If you do have an anti-malware program installed, you should check to see if the malware detection rules are current. Most anti-malware programs will let you view the version and last update date of the anti-malware program itself, and the last update date for the detections rules. The rules themselves should be update almost daily, due to the number of new threats emerging every day.
Sep 12, 2017 | Microsoft Windows XP Home Edition
How do we get wireless hookup to PC in rural area no cable or DSL
You will have to use a wireless cell phone type of modem. Some hi end cell phones like, blackberry's and some blackjack's have this capibility, to be used as a computer internet modem, see your local cell phone co. This service will be a bit expensive.
Aug 31, 2009 | Compaq Presario 5000 PC Desktop
Connection a Netbook to dial up
if your netbook doesnt have built in dialup modem that mean u cant connect it to a dial up connection. most of netbook in market use wifi as primary connection or sometime comes with built in GSM modem to connect to internet. that meanc the option you can try is to buy a external USB dial up modem
Mar 26, 2009 | Advent 4211c Notebook
What is a dial out code?
A dial-out code is a number that is automatically added when you dial a number. It can be either your area code or (usually) your country code.
Let's say the number stored in your phone is (123) 456-7899. So if your dial-out code is set to "+1", then the number dialed is +1-123-456-7899. This ensures that, wherever you are on this planet, you will always reach that number in the US.
On home phones you can sometimes set a dial-out code (like "123"), and if you dial 456-7899, then it automatically adds your area code to the number.
What sometimes happens is, let's say you bought your phone in the US, but you live in another country, your phone still automatically adds a "+1" to all your numbers stored in your phone unless specified otherwise. That's why you have to set the dial-out code to your specific region.
Jan 11, 2009 | Innovage Lands Phones
I just bought a new laptop and I alredy have another on the line. How do we get the original and the two laptops on the one line?
1 new laptop, another already on the line, then you mention wanting the original and the 2 laptops on one line. So is the "original" hard wired to the router ? Meaning not on a wireless connection. By one line, are you wanting to be able to do file shareing between the 3 ? Is that what you are referring to or something else? Were the 1st laptop and the original set up like you want to have the network set up now ? You may need to go into the configuration settings of the router and make sure that the maximum number of users is more than one.Find this under the Basic Setup tab>Network Setup. Would say something like Capture(setupcontent.maxdhcpusr)Maximum Number of DHCP Users:
The router manufacturer website may have additional help to help make sure all the configuration settings are correct. They may offer free Live Chat support or if the router is still under warranty they should have tech support by phone.
Windows has a network connection wizard located in the Control Panel that should be able to do what you are wanting.
Nov 18, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Bose media mate speakers suddenly don't work after ....
what type of computer? desktop or laptop? have you changed or added a sound-card?
Jun 24, 2008 | Bose MediaMate Computer Speakers
Internet
There are a few ways you can use wireless to get the laptop online. The easiest way would to buy 1. Wireless Router and 2. Wireless USB Adapter. Follow link for some pretty good instructions to setup a home wireless network.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Chris
May 28, 2008 | Computers & Internet
I live out in the country 1 mile from town and I got a wireless-g 2.4 ghz Linksys usb network setup adapter. how do I make it work?
Do you have internet access? dial-up, DSL or Cable? or is this a LAN only? What operating system? XP, Linux, Vista?
The software CD that comes with it is installed first, then you are asked to insert the USB NIC. That will make it 'work", but there must be a wireless network in range to connect. Do you have a wireless access point? One mile is too far for you to access any free WAPs in town, like Starbucks or something. If it is a laptop, I suggest a ride into town to test it out.
Mar 26, 2008 | Computers & Internet
D-Link DI 713p (DI-713P) Wireless Router Logo
232 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
