Question about Denon AVR-1500
Amp comes on and goes right into protection mode I turn on my Denon stereo receiver AVR-1500 an it goes to protection mode? Can someone please help me?
  • cvprice Jan 05, 2009
    same problem. had it repaired twice and still same problem. $1200 in debt for a piece of junk.
  • 3 Answers
Do you still have the AVR1500? I have one with a bad tuner--and would be interested in purchasing your for parts. Let me know if you still have it and if you'd be willing to sell it.
Posted on Apr 29, 2009
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Jul 31, 2007 | Denon AVR-2800 Receiver
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
Trip problem
If your receiver goes in to the protect mode or shuts off you have shorted output transistors
Apr 10, 2010 | Denon AVR-1705 Receiver
No surround on Denon AVR-485
Hi you must put the amp into prolgic mode this is fed by a stereo siganal the rears will sound vague and hollow that's all you will get this willnot work with 5.1 or 7.1 good luck
Feb 22, 2009 | Denon AVR-485 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
My Denon AVR5800 Receiver Shut itself off after I turned it on?
This amp is going into protect mode as it is sensing an internal overload,needs to be repaired...
Jan 08, 2009 | Denon AVR-5800 Receiver
Protection on display
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Denon AVR-1506 Receiver
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
412 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
