Question about Magellan Roadmate 760 GPS Receiver
Voice instruction problem
My GPS has lost the voice instruction, I have tried the volume up and down,the volume test and nothing happens. Do I need to send the unit for repair? if yes, where? Than you for your help.
  • Rogelio Galvez Feb 07, 2007
    Daniel, thank you very much for your help I followed your directions and it didn't work so I took the two screws that hold the speaker in place and I found a paper staple on the speaker,it was pull by the magnet behinde the speaker.I hope this will give you another idea where to check.
    Thank again,I will keep your solution in mine.
    Rogelio
    Novelist:
    Scholar:
  • 86 Answers
I'm guessing the touch screen is working fine regardless of the sound? What you'll need is contact cleaner and a thin cleaning rag. Disassemble the unit, being very careful when you first open it up to UNPLUG the RF cable that could break off if pulled too hard. So, once you get the 4 screws off, open the unit just a little bit.. reach in and unplug the RF cable. It will help your percentages of success if you were grounded somehow in this process. Take the HDD off the back of the mainboard (big board). Isolated from the rest of the unit, spray the contact cleaner directly into the volume knob.. then while still wet, use the cloth like floss and clean underneath the dial, all the way around the unit. Make sure you clean it thoroughly, so you don't have to assemble and reassemble it incase of failure. Put it all back together.. making sure ALL the cables are back in their original place.. and that should fixya. -Daniel
Posted on Feb 03, 2007
  • Daniel daniel
    Daniel daniel Feb 10, 2007
    wow.. so a staple on the front of your speaker was preventing sound from working?? The front, since you had to take two screws off the antenna right? hmph. .
SOURCE:
My garmin wont talk
Select another voice - if nothing upload a new voice such as the free voice:
http://www8.garmin.com/vehicles/voice.html?vName=DrNightmare
Select this voice and plan a route. If still nothing check the basics such as volume or volume mute.
Jun 30, 2011 | Garmin nuvi 200W GPS
How to adjust the volume? Volume is barely audible. Tom Tom 550TM
You can use the PREFERENCES menu option to change the volume of the voice instructions. Use 'Volume preferences' pref06.gif, with its sliding scale to set the required volume in increments of 5%.
The 'Test' function is a good way to get the volume right before starting your journey. You may also find it helpful to use 'Link volume to car speed', so that the voice instructions get louder as road noise increases and are at their quietest when you are stationary.
Jan 02, 2011 | Tomtom XXL 550tm GPS Receiver
I have a garmin 350 NA that has lost the voice on it. How can I get it back??
First press the speaker symbol and check that the volume is not down fully or that the mute box is not ticked. If it is press the mute box to untick it or increase the volume. Otherwise follow the instructions below.
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Oct 15, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin/nuvi 265w has lost its voice
Sep 16, 2010 | GPS
How do i change my tom tom one from spanish back to english
Do you want to change the language of the VOICE or the WORDS IN THE SCREEN? These two are independent from each other and need to be set up by separate.
1) To change the VOICE, you need to download an ENGLISH VOICE or have it in your GPS already.
a) Start TomTom Home on your computer.
b) Plug in the TomTom dock to a USB port on your computer and plug in your TomTom GPS on the dock
c) Turn on the GPS and when asked "connect to computer" answer "yes" (you may not be asked if you want to connect; TomTom Home amy detect your GPS and connect to it automatically). If your GPS is not connecting to TomTom Home, turn the GPS off, turn it upside down and press the "reset" button for 7 seconds, place the GPS back on the dock and turn it on. It should automatically connect to TomTom Home now.
d) On the TomTom Home software, click on the icon labeled "Add Traffic, Voice, cameras..."
e) Click on the icon labeled "voices"
f) Click on the icon labeled "computer voices"
g) Click on any of the voices that says "English" on the second ("language") column; download and install the voice
h) Go to the TomTom Home top menu and under "DEVICE" choose "DISCONNECT DEVICE". Wait a few seconds until the GPS communication with the computer is broken and the GPS restarts. You don't need the computer anymore for now
i) On your TomTOm GPS, tap on the middle of the screen to bring the menu.
j) Touch "CHANGE PREFERENCES"
k) Touch "VOICE PREFERENCES"
l) Touch "CHANGE VOICE"
m) Select any of the voices that are in English (such as "SUSAN, English US, Computer"). After this, you can TEST the voice. Check that you can hear the voice, otherwise, you'll need to adjust the volume. We'll do this later. Touch "SELECT" to select the voice. Press "DONE" on the next 3 screens until you're back to the GPS navigation screen
n) To change the volume, tap on the LOWER LEFT rectangle. You'll get a VOLUME SLIDE. Slide it to the RIGHT to increase the volume and to the LEFT to lower it. I keep mine around 85% volume.
YOU ARE DONE SETTING UP A NEW VOICE
2) To change the LANGUAGE of the WRITTEN DIRECTIONS on the screen:
a) On your TomTom GPS screen, tap on the middle of the screen to bring the MAIN MENU on
b) Tap on the PREFERENCES icon
c) Tap on the RIGHT ARROW 7 times or until you see an icon labeled "CHANGE LANGUAGE".
d) Using the UO and DOWN arrows on the GPS screen, scroll up or down untill you see the langauges you're looking for. You'll get a screen with several languages available, including "English UK" and "English US"
d) Touch on the screen you want. The screen will automatically go back to the previous menu screen that shows the "CHANGE LANGUAGE" icon. Touch the "DONE" button.
YOU ARE ALL DONE. Now, your VOICE and all WRITTEN DIRECTIONS should be in ENGLISH.
If this didn't work, please report back so that I can provide further assistance
Apr 01, 2010 | Tomtom ONE GPS Receiver
How can I get everything in English please help!
1) To change the VOICE, you need to download an ENGLISH VOICE.
Mar 31, 2010 | Tomtom XXL 540S GPS Receiver
My tom tom has spanish language i need english language
n) To change the volume, tap on the LOWER LEFT rectangle. You'll get a VOLUME SLIDE. Slide it to the RIGHT to increase the volume and to the LEFT to lower it. I keep mine around 85% volume. YOU ARE DONE SETTING UP A NEW VOICE
If this didn't work, please report back so that I can provide further assitance
Mar 27, 2010 | Tomtom GO GPS Receiver
How should i chage the language on tomtom to
a) Start TomTom2_bing.gif Home on your computer.
b) Plug in2_bing.gif the TomTom dock to a USB port on your computer and plug in your TomTom GPS2_bing.gif on the dock
c) Turn on the GPS and when asked "connect to computer" answer "yes" (you may not be asked if you want to connect; TomTom2_bing.gif Home amy detect your GPS and connect to it automatically). If your GPS is not connecting to TomTom Home, turn the GPS off, turn it upside down and press the "reset" button for 7 seconds, place the GPS back on the dock and turn it on. It should automatically connect to TomTom Home now.
Mar 21, 2010 | Tomtom GO GPS Receiver
Is battery replaceable and voice does not work all the time
Computer voices, if stored on the unit and enabled, will give you all instructions (turn, ahead, street names, etc.) Custom voices (Simpsons, star voices, etc.) can only egg you on, but cannot say the name of streets. Make sure that you have at least one computer voice in your favorite language.
Jan 17, 2010 | Tomtom GO 920 GPS Receiver
Sound
If you lost "all" sound - click the speaker icon (bottom of screen) and make sure all volume is turned up. If you lost just the voice prompt for turns etc. This happens when you have an extended period of low battery. You need to reinstall the setup CD for the iQue 3600 go through the motions and HotSync the unit - This will reload your voice files.. Jerry ... gandg22@yahoo.com
Aug 15, 2007 | Garmin iQue 3600 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
97 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
