Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
Melded mass of ice in bin
Here is what I know: Ice Maker Model Number CME456A8-1B; Ice Maker Serial Number 687872-018; Ice Bin Model Number B322S; Ice Bin Serial Number 08081320010761; Product Manual in hand, circa 2003, but no help regarding the current problem.
Current Problem: Most of the ice cubes freeze into a solid block of ice; After removal of only about 10 – 15 pounds of ice, you run into the solid block of melded ice cubes; The bin was emptied about 5 days ago, thinking that the accumulation of the solid mass of ice cubes was caused by lack of consistent use over a period of time; Within two days, the bin was full of ice again, and the solid block of melded cubes was back; The size of the melded mass of ice cubes goes from the bottom of the bin clear up past the baffle in the back and about 16 inches high in the front, measured from the bottom of the bin, and about 16 inches deep toward the top of the bin, measured from the back of the bin, and fully deep on the bottom; Or, put more simply, the melded mass of ice cubes takes up about two thirds of the bin.
Can you help?
  • 102 Answers
Your unit could be cascading water into bin..make sure baffle in the back is on..if you put your hand in bin where ice falls..youll feel a considerate amount of water falling...make sure your keeping door closed...just turn off..bout half way full..see if it makes a difference
Posted on Jan 26, 2010
    Guru:
  • 462 Answers
The only thing I can offer is to limit the out put of the machine closer to what your needs are.Or bag the ice and store in a freezer. The ice pushing down while melting is what is causing the BIG FREEZE. The bin for storage may be too big for your needs, at least at the time you write this. When the demand goes up (warmer weather) the ice would be used more and the pressure pushing down will alternate as well as people getting scoops out more often this will help prevent such a freeze up in warmer weather.
Posted on Jun 02, 2009
  • Farley Redfield
    Farley Redfield Jun 06, 2009
    DId you understand what is causing your problem?
My ice in ice maker melted then frozen again..ice maker not making ice. how do i remove the ice bulid-up in the tray and how do i reset the ice maker to produce ice?
First, clean out ice in ice bin by removing bin and rinsing water over it to melt ice. The remelting and freezing of your ice is probably not to refreezing but probably do to your water solenoid valve not completely shutting after the fill cycle and spilling over into bin and then freezing. Take your model number to searspartsdirect.com and you should find your solenoid water valve on the water circuit diagram.
Sep 28, 2014 | Maytag Refrigerators
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Not making ice
What is the model number of your unit?
Nov 30, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Ice maker not dispensing ice
Hi!!1 in order for the ice harvest the freezer must be atleast 10 degrees make sure..I wish that i knew which brand of frig you have.you are going to have to manually jump start the ice maker and see what happens..Good luck..Let me know model number and serial..
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Nov 21, 2008 | Whirlpool Refrigerators
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
408 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
