I've got a mobile computer samsung r510 and was provided with vista. I changed for XP and now the FN key in blue don't work anymore ! please help
  • 35 Answers
Function keys on notebooks require drivers during the installation it should have seen that it was a notebook and installed the correct "keyboard driver" I suspect that it may have not. You will need to go into your settings under hardware and see what type of keyboard is installed that will solve your issue.
Posted on Dec 02, 2008
Samsung NC10: Severe Fn key problem
i would check the bios for an option to keep fn always on and disable that. i would also try updating the bios. THIS HAS NOTHING TO DO WITH THE OS
Feb 26, 2014 | Samsung NC10-14GW Notebook
Samsung r510 laptop
I guess you mean the keyboard function act as though the fn key is always being pressed? If so this is likely to be a hardware problem. Look at gently prying up the key (most keys are press fit and can be removed, lift it off as level as you can, should be relatively easy but don't force it!) once off try moving the rubber pad below the key with a small blunt instrument, keep testing other keys while doing it to see if the fn effect ever lifts of, may have got wet or something underneath the key.
Nov 28, 2013 | Lenovo Keyboard
Every time I boot my EEE PC the touchopad is disabled. I plug in a USB mouse, enable the Elan smartpad through the properties of the Elan smartpad and it works ok until I reboot again. How do I enable it...
Usually there is a FN key that will enable the touchpad. I have EEPC and mine is the little blue FN key (usually next to the CTRL and Windows Key) + one of the number keys. Look for a little blue symbol that looks like your touchpad.
As for it being disabled every time you start, I find that very weird. Sometimes installing a wireless mouse, installs software that tells the system to disable the touchpad, so that the 2 don't conflict when using the mouse.
Aug 28, 2011 | Computers & Internet
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
Unlocking a samsung sch-r510 l
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This may be a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Jan 30, 2010 | Samsung Wafer (SCH-r510) Cellular Phone
Audio driver installation on samsung laptop r510 with xp
Hi. You may need to uninstall the driver for the realtek HD audio and try to reinstall it or go to the Samsung's website to download the latest audio driver for your Laptop.
Jul 30, 2009 | Computers & Internet
Vista ultimate key
Assuming you can use your computer still in vista try the link i have provided below.
http://www.mydigitallife.info/2006/11/05/view-and-retrieve-or-change-windows-xp-vista-2003-2000-and-more-and-office-xp-2003-92-product-key-or-cd-key/
There are many programs for viewing the key while in windows so that you can write it down. Please be careful though as Microsoft looks down on these things.
Oct 03, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
