I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
On the Calculator, There is a little Calender and Clock Button Hit is then hit the = button until the Number Blinks, When it Blinks type in the numbered date and hit the = Button when your finish.
Tutorial video:
If you can not get it to set you may need to push the reset button located underneth the unit
You forgot to say that after you make your changes you have to push the equal (=) key again to set it. also it's the divide key that changes the am/pm.
setting date
how can i set my clock
No owner's manual. Would like to set date and time. Please help!!
This is the first website I have looked at for instructions for this calculator.
Don't have the instruction to set my time and date on the calculator
I do not have the instruction manual for my Canon P170-DH calculator. I do not know how to load the paper , set the clock and other functions.
how do you set clock and calendar? lost the instructions..
OK this was great help when trying to set my date/time when I first got this Canon, BUT somehow this morning I changed it to military time and I need to change back... HELP how do I make it go back?
Thanks
Cheri
How do you set the clock on the Canon p170-DH
cant set the date .
set
don't Know how to set the Calander and clock and I've tried every botton please help
How do I set the time and date?
Cannot find instruction book. How do I set date and time on my calculator? Canon P170-DS
Canon P17-DH
cannot find instruction book.
How do I set time and date function
I had the same problem. Just go to http://www.canon.com and go to customer service help and ask them to send you the manual as an attachment. It's a PDF file. I did it and less than five minutes later, they send me an e-mail with the manual.
placing paper in calulator
how do you use the calculator to do the following problem:
(432x39.50) - (432/4)=
Please advice
