Question about Lite On Televison & Video
I tried to upgrade my DVD player / recorder, but something went wrong. After it read the upgrade disk, it wouldn't reboot correctly and now will not come on at all.
  • 5 more comments
  • Thomas Miovas
    Thomas Miovas Dec 02, 2008
    I have a Lite On DVD player recorder that I tried to upgrade using their upgrade software that I put onto a disk. After installing the upgrade, my DVD player / recorder is unresponsive. Someone suggested unplugging it for a while, so I did that for an hour and it still won't do anything. It seems to be trying, but it will not actually turn on. If no one has a better suggestion, how do I find a good repair shop for it?
  • Thomas Miovas
    I oroginally tried to upgrade the DVD recorder / player because it was no longer accepting new disks for recording. It would record once or twice, and then it tried to re-format the disk and then would tell me the disk was invalid.
    After trying the upgrade, which it seemed to accept, it won't do anything.
  • Thomas Miovas
    Well, if the only advise I am going to recieve is to unplug the DVD player off for a while and then plug it back in,or take it to a repair shop, then I don't think that is very helpful. I tried that and it didn't work.
  • Thomas Miovas
    Do I have to pay for the advise to take it to a repair shop? I mean, I appreciate the help, but I was looking for a solution that didn't require taking it to a repair shop from the FixYa experts. They sound like they know what they are talking about, and I need to get it repaired, but is that worth $10?
  • Thomas Miovas
    It's a Lite On DVD player / recorder, model number LVW-1101HC1. Even after unplugging it several times, it has no response, so I don't see how I can get it to do anything.
    Thanks!
  • Thomas Miovas
    For the series of right button then numbers, that didn'twork, as the front panel light is not coming on at all. It is completely unresponsive. If it would come on, I could reset it internally, but it won't come on. Sorry, those solutions failed.
  • Thomas Miovas
    I'm not sure what the comment was for about re-installing Windows. It is not a Windows computer, but a DVD Player / Recorder.
    Sergeant:
    Champion:
  • 258 Answers
I can't pinpoint where's the problem could you tell me what kind of dvd player were you using?
Posted on Dec 02, 2008
  • 849 Answers
Re-installing of windows is the best option of recognize all new devices.
  • Muhammad Saeed
    Muhammad Saeed Dec 02, 2008
    oh, i see
    if it not works, roll back it if it had option.
  • 6,487 Answers
Some upgrade ends with this type of problem that the player will not be responsive at all, so what you can do here is to look for a nearest electronic repair shop on your place and they can revert that player back to its original condition...
  • Lite On Master
  • 4,806 Answers
Your firmware flash has failed and dissabled the DVD/RW altogether, power down the machine and the power up again, look to see if the LED indicator on the DVD lights up, if it does there is a very good chance you can reflash the DVD again, make sure that you have got the right firmware!!
One of my customers did exactly the same and i could ony get it to read and write DVD after that
Don't let that put you off, there is a chance you can save it!!!!
Post back with the results please
Regards
  • Lee Hodgson
    Lee Hodgson Dec 02, 2008
    try a reset press: "right" key, then 5, 0, 0, 1 and 'enter or Right" key, then 5, 0, 2, 0 and 'enter'
    or, with the unit powered on, SETUP, right (cursor), down (cursor) 6 times, right (cursor), then press ENTER (this will do a system restore)
    hope this works
  • Lee Hodgson
    take it apart and find the reset button but that is NG. also reset the power and even leave it totally disconnected with no power for a day, nothing when pluged into the outlet. The dvd player might not work if you get power back to it.
    If its under warranty have it repaired, it costs nothing
    regards
  • 1,879 Answers
Leave it unpowered for at least 5 minutes. Try it on again, if it does not give you the option to load the upgrade again, there's nothing you can do about it except have the manufacturer that provided the upgrade to take a look at it (as they should release a headache free upgrades).
Posted on Dec 01, 2008
    Master:
  • 474 Answers
Allright, sounds like it may have been a bad file or update. Why where you updating it? did it have some other issues?
Have you tried unplugging it and giving it a while, then plugging it back in?
Try that, then turn the power on and give it a while, maybe it just needs time to setup the files.
  • Chris Busch
    Chris Busch Dec 02, 2008
    Im assuming you did all this right? They do offer online support through a chat program like Dell does. Go to there website and try it, you payed for it, use there service before giving up. It sounds like it a particular issue and most of us giving advice is for something more in general. You need to talk to them, they may have the issue alot and have a fast answer. heres a quick link ( http://us.liteonit.com/us/index.php?opti... ) Oh, and the reason people where telling you to unplug it and plug back in is because that is how you reset most devices in general, in your case it didnt work, sorry. I have had a few LiteOn drive in my computer before and ever one has crapped out without warning due to upgraded firmware or for just no reason.
    Good Luck
    Before you start...
    You need the following items to proceed the firmware upgrade procedure.
    • A personal computer
    • Data compression utility (for example, WinZIP or WinRAR)
    • A CD-R/RW drive and writing application software (for example, NERO)
    • A blank CD-R
    Download the software to your computer
    1. Click the 'Download' link to save the zip file into your computer.
    2. Unzip the .zip file and extract files (if any) into your computer.
      Please do not change the filenames.
    Create the upgrade disc
    1. Open the writing application software (for example, NERO).
    2. Select File / New, and then get the following.
    3. Make 'CD-ROM (ISO)' to choose 'New' item in the right and then enter the browser window.
    4. Select all of the extracted files and drag to the left side ISO list.
    5. Start to burn by pressing the 'Writh CD' selection.
    6. Wait for the finish message.
    Steps to upgrade firmware on your DVD recorder
    1. Power on the set and open tray.
    2. Insert the prepared upgrade disc and close the tray.
    3. The upgrade process starts. Please do follow the indications displayed on the screen.
    4. When the upgrade is successful, please remove the upgrade disc from the tray (if the disc is still there). Then power off and on again with the 'POWER' button.
    [Close]
  • Chris Busch
    Oh, one more thing, have you tried just holding down the power button for 3 to 5 seconds and seeing if the unit will come on. Alot of manufacturers have that as a kind of reboot function, kind of like computers when they freez. Give it a try.
    Sergeant:
  • 217 Answers
Unplug it from main board for some time then reconnect it properly and checkout.
  • 1,512 Answers
HI
What make and model do you have?
regards
robotek
  • Graeme Ross
    Graeme Ross Dec 01, 2008
    If the unit is not booting correctly, firstly, have you allowed for a complete powerdown(disconnect from the wall socket for 10 mins) ro reset the unit entirely. This will allow for the new firmware to begin from the upgraded files. If this is not successful, you may need to reverse the upgrade and try again. With the make and model, I can find a procedure to facilitate this for you.
    regards
    robotek
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
What other DVD recorders will finalize my Insignia DVD's?
i had same problem, the laser is going bad. soon it will not read any disks.
and had many disks not finalized. so i bought a new one (jvc) and it does read the other disks not finalized. hope this helps
Jan 14, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
DVD recorder continually stuck on a loop trying to read disk.
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Dec 28, 2008 | Panasonic DMR-E55 DVD Recorder
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
Panasonic Dvd recorder DMR-E50 is locking up. I get the disk error. I can't record or finalize. When I try to title it won't let me. It's not bad disks, I've tried all of them. If I try to record, it...
Greetings deb2531,
I had the same type of problem with my DMR-H2. Unfortunately it may be something physically wrong with your unit.
I had brought mine in to a BestBuy™service center, and they had to replace a internal part or board.
With the ever dropping costs of home theater DVD Burners it might be time to upgrade in place of repair.
Sorry I couldn't be more help.
Jon
Go Ahead. Use Us.
May 20, 2008 | Televison & Video
Can't Finalize Disk after recording
Your problem may be media related.This firmware upgrade has
helped me and others with similiar issues.
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders#
Be sure to read the instructions.If you don't know understand the
instructions,don't try it.You may make your recorder unusable.
http://www2.panasonic.com/static/Content/productsupport/dvd_firmware_instructions.pdf
Apr 03, 2008 | Panasonic DMR-E55 DVD Recorder
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Disk error
can you hear the cd spin?
more times than not the laser is bad.
Oct 18, 2007 | Sony RDR-VX525 DVD Recorder/VCR
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
13 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
