Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Annoying background image
I have this extremely annoying problem with my monitor. A small box - centered on the screen - pops up nearly all the time. It is semi-transparent and simply says "0 [degrees]" degrees = the symbol for angle. It is certainly something integral to the monitor and I do not believe it is associated with a driver or anythign like that. Can anyone provide advice on how to disable this very annoying feature? I have been extremely disappointed with this Samsung monitor, I DO NOT recommend it for anyone else. Ken
  • Ken Westrick Jan 29, 2007
    This is not the problem, it does this from the minute that the monitor is turned off, even after weeks of being turned off. It is due to small vibrations, not heat.
    Novelist:
    Champion:
  • 202 Answers
Ken, Unplugging the monitor for 48+ hours to disapate all electronics within the monitor may work. otherwise its probably a heat problem. When the monitor heats up something stops doing its job. Tim
Posted on Jan 29, 2007
  • Timothy Higgins
    Timothy Higgins Jan 29, 2007
    I am sure you have tried this but here it is: Resetting Current Samsung Monitors
    To reset most current Samsung monitors to their factory settings, follow these steps:
    1. Press the Menu button on the monitor. The OSD menu appears.
    2. Press the Adjust (up or down arrow) button on the monitor to change the menu window until you see the window containing Autosource, Image Reset, and Color Reset.
    3. Press the Select button on the monitor to select the this window.
    4. Press the Adjust button to highlight either Image Reset or Color Reset.
    5. Press the Select button. The Image Reset or Color Reset window appears.
    6. Press the Brightness/Adjust button on your monitor. Yes is highlighted.
    Note: As soon as you select Yes, the monitor resets to the factory presets.
    7. Press the Menu button on the monitor three times to exit.
    Note: You must perform both Image Reset and Color Reset to reset your monitor completely to factory presets.
    Resetting Older Samsung Monitors
    To reset most older model Samsung monitors to their factory presets, follow these steps:
    2. Press the + or - button or the Up or Down arrow button on the monitor to change the menu until you see the Reset Menu.
    3. Press the Menu button to select the Reset Menu.
    4. Press the Up or Down button on your monitor to highlight Geometry Reset or Color Reset.
    5. Press the Menu button to select either Geometry Reset or Color Reset.
    6. Press the Up or + button to select Yes.
    7. Press the Exit button on the monitor to exit the menu.
    Note: You must perform both Image or Geometry Reset and Color Reset to reset your monitor completely to factory presets.
Did you ever find a fix to this problem?
I also have the 0° transparent image!
Posted on May 16, 2008
Same problem here, anything yet?
Posted on Jun 29, 2010
I dont think these solutions will help for the issue. I came to know from my vendor that this is the problem related to Micro Controller inside the monitor. So i am gonna replace my DELL monitor with TFT Dell.
Anyhow some Geek must find what made to cause this issue.
Thanks Guys !
Posted on Sep 23, 2008
Boxes opening on screen often when I am typing. Am I hitting a key that is causing this?
That is usually the development inspector window to view HTML code that runs in the background to give the pages. it is usually a combination of key strokes such as ctrl+shift+k in the web browser Firefox. I would suggest to try a different web browser and go from there, if you don't want to switch more information is needed to help assist your problem (operating system "winddows 7,8, linux, mac", web browser, etc.
Nov 15, 2014 | ASUS Computers & Internet
The on/off button on my monitor doewn't work. in fact, none of the buttons work right. the annoying this is the screen for adjusting brightness, contrast, imaging, etc. keeps popping up
Sounds like one of the buttons is jammed or broken (stuck). Try pressing each button one at a time. Does one not click or feel like the others? You might need to pry at it a little to unstick it. Let me know if that works or not.
Jul 03, 2011 | Envision 19" Widescreen Flat Panel LCD...
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
Menu popping up
most common problem are loose board solder, LM7805 voltage regulator drifting,, bring the unit to a qualified monitor repair center near you...
May 08, 2010 | Dell E773C 17" CRT Monitor
Audio adjust screen pop up
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Dec 20, 2008 | Computers & Internet
Hp.f1703 in centre of screen small blue instructions regarding OSD and default settings for contrast appears from time to time without me pressing the buttons. This is very annoying whilst working.
this may be your monitor settings popping up. i had a monitor and limmitted space and the keyboard kep hitting the menu button on the monitor, it was very annoying with the menu popping up while i was gaming, untill i figured it out.
moving the monitor back a few inches solved the problem
Oct 24, 2008 | Computers & Internet
Image not displaying properly
Before assuming it's the monitor, try it on another display card.
It is possible that there is a problem in the configuration of the display card, or a defect in the display card.
Is there a computer service place, or a monitor sevice center near to where you live. You can then take the monitor to have it properly checked for you.
Jerry G.
Jun 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Annoying discolouration across monitor
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Feb 13, 2008 | Acer AL1916W 19" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
586 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
