CONNECTING TO A NETGEAR DG834GT ROUTER
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
SOURCE: sky branded Netgear DG834GT router
OK - it can be very simple to do, but took me two hours to work out ;-)
Google for all the info you can.
Download the recovery utility from Netgear.
Download the latest OS from Netgear.
Flash the router with the OS.
Enter the router config panel.
Change the Sky login and password to the ones given you by your ISP.
That should be that.
Keep trying: I did, I'm no expert, and I got there.
Do everything you can to a*sf*ck Murdoch and his company.
SOURCE: How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
SOURCE: Connecting to http://192.168.0.1
You need to use the desktop computer to access the Netgear page. Check the default gateway address of your desktop (this is the IP address of your Netgear). You may follow these steps if you don't know how to check the IP address of your desktop:
1. Go to the Command prompt or DOS prompt. Type in ipconfig and press enter. Check the Default Gateway address.
SOURCE: connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
