Question about Bose & Wave& Music System
Music Wave Machince will not turn on, clock is working.
Unit is plugged into the wall outlet and the clock is working. I've unplugged it for a few minutes, plugged it back in, etc... and it still will not turn on. I've disconnected all the wires and reattached, still will not turn on. Any tips to get the machine to turn on?
    New Friend:
  • 59 Answers
It sounds like the power button has failed. either call Bose to get a RA# and the nearest service center, or find an adventurous electronics tech in your area to replace the switch
Posted on Dec 05, 2008
Why my Home Radio does not work?
Try different outlet. If still nothing then something may be wrong with the power supply of unit.
Jun 25, 2016 | Bose & Wave& Music System
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
When I plug my Bose clock radio into one outlet, I get nothing but static. When I plug it into a nearby outlet (with out really moving the cord), I get perfect reception. The problem is the outlet where...
The Wave Radio uses the AC power cord as an antenna. Perhaps the two outlets are wired differently regarding ground and hot.
An interesting article...
http://www.gcaudio.com/resources/howtos/acpolarity.html
As the man says in the article thecircuit tester like this...
http://www.idealindustries.com/products/test_measurement/electrical_testers/circuit_tester_e-z_check.jsp
... can be found at many Dollar Stores for cheap.
Mar 06, 2011 | Bose Wave Radio
My wii won't turn on and I tried unplugging and disconnecting all the cords and it still won't work...any suggestions???
First verify the outlet on wall you are plugging the Wii into works.
Unplug the power cord from Wii AND the wall to allow proper discharge of the power unit. If you do not unplug from wall outlet to then the power unit will not discharge.
It could take up to 15-30 minutes sometimes.
Mar 01, 2011 | Nintendo Wii Console
Bose wave radio won't turn on; power on but clock won't even work
Worked on a bunch of these. If the clock does not work you have no power to the circuits. If the wall receptacle has power then you probably have a blown fuse. If you replace it make sure it is the exact same value. If it blows when you turn it on you probably have bigger problems. If you are not a tech or familiar with electronics you will probably need to have someone fix your unit.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Bose Wave Radio
First cd works fine but bose won't shift to the other 3 CD's...keeps saying "error" . I have tried unplugging the AC cord and then plugging it in again...worked for awhile but now doesn't work...
Check the pins on the cable that's plugged into "BoseLink" on the Wave Music System. If even 1 pin is bent, this could happen. If that looks fine, try another reset, but keep the power unplugged for at least 30+ seconds. If this fails, call Bose tech support at 800-367-4008. If this is under warranty, they will fix this or replace it for free, otherwise it will be about $75 to fix.
Jun 18, 2009 | Bose Wave Radio
Bose Wave unplugged now it won't power up when plugged back in
I will first start check the power section circuitry of your Bose Wave radio. Are you electronics savvy?
Jun 16, 2009 | Bose Wave Radio
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Bose & Wave& Music System Logo
76 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
