Question about Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television
Pixel color fade
On occassion when the tv is on, there is a change in the pixel color on top of the tv screan which displays a lack of color and uniformaty in the pixel on the screan. It's usually about 5 inches by 12 inches wide. The tv needs to be shut off because I'm noticing it's hot in those areas where the pixel discoloration appears.It display a white to green color on the affected area.
  • BROWNI May 11, 2008
    TOP OF THE SCREEN IS GRREN AND EURO SPORT IS BURNT IN TO IT
  • KeithRL Jul 06, 2008
    I began having green "speckles" (the repairman's term) after over 3 years of use. Fortunately it was still under the extended warranty. However, after 8+ visits and replacing every circuit board in the TV the problem remains 9 months later. They now say that they will replace the panel, but I have been waiting for them to get the part for 2 months now, and today the green portions of the screen encompassed most of the top portion of the screen.
    The repairman thinks that they should just replace the TV but they keep wasting money with more parts and labor. In the meantime I have lost my patince and have threatened Pioneer with legal action if they do not repair/replace ASAP. What good is the warranty if they don't stand behind it. Based on this experience I will never purcahseanother high end Pioneer product and will not use Best Buy for such purchases either.
  • 103 Answers
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Posted on Mar 22, 2007
How can I fix my this ? Pixel colour fades on screan , though battery is fully charge , how can I fix this please?
some computers will fade the screen automatically when on battery power. on windows systems, you can change those settings (normally) by going to Control Panel -> Hardware and Sound -> Power Options -> Edit Plan Settings (beside the option in use) -> change advanced power settings -> Display (see screen shot)
Sep 14, 2015 | Samsung GT-N8013EAYXAR - 10 1 Galaxy NOTE...
I have a 42 in Sanyo DP42647. If there is something like a logo or words that stay on the screen for more than a few seconds it looks like it is burned in. It eventually fades but by the time one fades...
Cause of screen burn typically is pixels are no longer showing full range of color. Typically a shop would cycle screens or blocks of very bright colors alternating colors to unstick any pixels not showing full range of some color. Setting tv back to factory default then adjusting could help also turning up brightness. Change color settings from cool to warm could help. Could also be a refresh rate. Verify tv is set to display at same rate as input device like cable box set to output 1080i while tv native is 720p. Just because there is a pic doesn't mean they are synced.if tv has to convert signal from 1080i to 540i then resize to fit 720p tv it may slow refresh rate tv is trying to display progressive scan image but not enough data is coming in so it redisplays previous image on every other line.and new data on every other line.
solution is check output video settings of source to match native resolution of tv. Hd cable box this is common as tech sets output to high resolution 1080i most inexpensive tv are 720p
Mar 14, 2014 | Sanyo 42 in. LCD TV
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
I adjusted the color on my Display settings and now I can hear but cant see out of range Megahertz?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 11, 2012 | HP Computers & Internet
Phone has begun going 2 a white screen & the pixels are messed up
Yes, its one of two things, the LCD (display) is faulty or the LCD ribbon cable that links the top half oh the phone to the bottom is failling, a common problem on samsungs, but a cheap easy fix.
Oct 26, 2009 | Samsung Propel A767 Cell Phone
There are horizontal color bands (red, yellow and purple) scrolling from the bottom to the top of my 32" insignia flat creen TV. i've owned the set for a year and it has been perfect up till now. anyguess...
sounds like you have some lines of dead pixels, is this an LCD screan or a plasma screen? if it's LCD then it is dead or stuck pixels, check your owners manual and there should be a section on stuck pixels if its and LCD tv.
May 11, 2009 | Insignia IS-LCDTV32 32 in. Television
Lines in screen
They are stuck pixels...
There are some that say sending strong images that change from to color to color can help unstick them, but I say only dissassembly and cleaning of the contacts (there should be 2 ribbon cables, one for top, one for side) that probably got dust in it. Call it in under warranty if at all possible.
Apr 19, 2009 | Sony KDL-52XBR4 LCD Monitor
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Mitsubishi CS26301 27" TV
Have you tried flipping the pictures so you can troubleshoot it from the larger screen?
Feb 16, 2007 | Mitsubishi WT-42315 42" TV
Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
291 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
