Question about Onkyo Audio Players & Recorders
I have an Onkyo TX-SR701 amp connected to 5 Polk speakers. Config was working fine. I now have no sound from the rear two speakers, or the subwoofer. "White noise" test from the amp shows the two rear speakers are fine. There normally was no sound during this test from the sub woofer. The sub was recently repaired by Polk for distortion. Any ideas? Thanks
    Genius:
  • 1,847 Answers
Replace the rear speaker with the front one and check does the issue is show on the front too.
Posted on Dec 01, 2008
    Sergeant:
  • 217 Answers
The wire must have gone loose most probably.or try inter changing the jacks to 1 another.
Onkyo TX-SR701 getting sound but not picture from Video 4
you should check the video mapping in the setup of the receiver. video 4 may be associated with hdmi or composite video instead of component.
Feb 21, 2014 | Onkyo Audio Players & Recorders
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
Can I use the SR701 as a public address amp? Does not seem to be a labelled microphone input.
You would need a microphone preamp/mixer to connect a mic; or a pre-amplified microphone that has a Line Level output.
http://en.wikipedia.org/wiki/Line_level
http://www.google.com/#hl=en&rlz=1R2ADFA_enUS360&q=pre-amplified+microphone&aq=f&aqi=&aql=&oq=&fp=baa94940edcea411
Whatever you do, be very careful to not have a feedback loop between the microphone and your speakers or you can kiss your tweeters goodbye.
Feb 24, 2010 | Onkyo TX-SR701 Receiver
Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
Jan 03, 2010 | Onkyo TX-SR701 Receiver
Hey , with the Onkyo TX-NR1000 can I get started plugging two speaker while I gather enough money to buy the surround sound speakers. Also your opinion on speaker choices is greatly appreciated. Thank you.
Sure you can only connect 2 speakers. As for brand recommendation Polk audio makes some fine sounding speakers also Klipsch, Boston acoustics, too many to suggest. If you have a Best Buy near you they usually have a speaker room with many different brands that you can listen to. Though that doesn't mean you have to buy them their. I'm partial to Polk audio though. Polk has excellent customer service. That's going to be a tough decision you should really do some research on the internet for cost to quality references. Good luck. I hope this gets you pointed in the right direction.
Nov 24, 2009 | Onkyo TX-NR1000 Receiver
I have an Onkyo TX-SR701 that won't turn on
The fuses are the first look, Then make sure that the speakers are connected properly and the wires are not shorting together. It sounds more like a power supply problem or logic controller problem if the unit will not fire up and as such unless you are into electronics then a repair center is the next option and most likely the quickest.
Oct 16, 2009 | Onkyo TX-SR701 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
