Question about Emerson EWR20V4 DVD Recorder/VCR
Programming errors I have two soaps I record every day Mon-Fri. I use dvd and the 6hr record time. Lately I've noticed that the timer settings are in error and I have to click setup on the remote to set them up for the next day. Even with both ready to record the second timer program never records because something is causing it to go into an error state. Because I'm as work when this is happening I can't troubleshoot it. Any suggestions?
    Problem Solver:
  • 5 Answers
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Posted on Jun 08, 2007
How do I set a program to record weekly, can do it 24 hours ahead up to one week.
On the timer record screen, move the cursor left to the 'date' field, and scroll down until the date disappears, and it only shows a day of the week. If it shows 'Mon', your programme will record every Monday.
Mar 06, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Magnavox MDR533HF7 timer programmer records wrong channel sometimes
You have to record some channels manually and you can not use the timer. Since TV went digital the channels are not really on the channel that you see. Where I live channel 5.2, 5.3, 5.4, and so on are really on channel 35 and 45. This tuner has a hard time with these channels because they are not on the station that you see and it does not look like this will be fixed.
Jun 20, 2014 | Magnavox Mdr533h Dvd Hdd Recorder
How to set it to 12 hours on 12 hours off
You posted under Woods 59377 timer.
Open following page to identify timer for sure:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Manual appears below
http://waterheatertimer.org/pdf/Woods-59377.pdf
1) When programming, you can set 8 programs with choices of different blocks of days.
In your case, you want 1 program (Prog1) for all days of the week: So when selecting days, you want MON, TUES, WED, THURS, FRI, SAT, SU to display
2) When programming, you first set Prog1 ON, and then select all days as shown above, then set hour for 12am, and then set minute for 00.
3) Secondly you set Prog2 OFF, and then select all days as shown above, then set hour for 12pm, and then set minute for 00.
4) If 12am and 12pm do not display for some reason, then set times for 11:59am and 11:59pm.
5) Programming steps:
-Press PROG button until 1 and ON display. This is Prog1 ON.
-Press DAY button to select days
-Press Hour button to set hour
-Press MIN button to set minute
-Prog1 ON is set
-Press PROG button until 1 and OFF display. This is Prog1 OFF.
-Press PROG button to validate settings
-Prog1 OFF is set
-Press CLOCK button to return to current time
6) Manual shows other features
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Woods Industries 59377 Indoor Digital...
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Nov 08, 2010 | Coleman Cable Woods 59018 InWall 7Day...
I can not boot sequence from DVD, it have lock by system password, how to reset system password ?
It appears that there is a BIOS password in your computer. Please call Dell Technical Support. They can reset the BIOS password over the phone.
Home 1-800-847-4096 8am - 9pm EST Mon - Fri Home Office 1-800-387-5757 8am - 8pm EST Mon - Fri Small Business 1-800-387-5757 8am - 8pm EST Mon - Fri Medium & Large Business 1-800-387-5757 8am - 8pm EST Mon - Fri Provincial Government 1-800-387-5757 8am - 8pm EST Mon - Fri Federal Government 1-800-387-5757 8am - 8pm EST Mon - Fri Education (K-12) 1-800-387-5757 8am - 8pm EST Mon - Fri
Mar 02, 2010 | Dell Inspiron XPS M140 Notebook
Pre-Set Timer program not recording
Just a hunch, but did you check the clock settings after the time change?
Nov 08, 2008 | Samsung DVD-V3650 DVD Player/VCR
Timer Recording
To schedule a weekly or Mon-Fri program on the DVD scroll back in the "date" box (instead of forward to a future date. You will have options for once a week or Mon-Fri.
Jul 27, 2008 | Panasonic DMR-E75V DVD Player/VCR
Recording
hey- i have the sansui vrdvd5000 and didn't have a manual (or a remote). i just ordered one here- hope this helps!
http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=VRDVD5000
Apr 21, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
HOW TO RECORD CONTIUOUSLY
what do you mean? you can set it to record mon-fri or
weekly. you do that on the timer. if you want to record the whole 6 or 8 hour tape
just press record the tape will go off itself at end of tape some vcrs you can set manual timers by pressing record button
more than once and can set to record up to 6 or 8 hours .
if it don't do that just leave it on record it will fill up tape until end
but will stay on same channel.
timers are unreliable if u make just one mistake it might miss
the show.
Nov 11, 2007 | Quasar VHQ940 VHS VCR
Emerson EWR20V4 DVD Recorder/VCR Logo
123 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
