Question about Iomega (11113) Internal ZIP Drive
My PC crashed, need drivers for the Iomega Zip 250 ATAPI 250MB
I purchased a Iomega Zip 250 ATAPI 250MB IDE Int Zip Drive 5 yrs ago. had issues with my PC shortly after. Now i wanted to use the drive with a newer pc and the drive needs drivers to work with this machine of mine. Modle # isz250atapi , P/N is 3016770. can you help ?
Www iomega com
I believe you can use a PATA drive to USB adaptor. Hopefully you have the software for the Iomega drive, or perhaps that is available from Iomega. I've never tried it with an Iomega but have with numerous other drives. I hope this helps.
May 18, 2013 | Iomega ZIP 250 - Disk drive - ZIP ( 250 MB...
I own a 250 meg. parallel port external Zip drive. This drive could once be used on DOS-based computers with software called GUEST.EXE and some drivers, with GUEST selecting the correct driver and...
Recomendation: Replace for a external hard drive, The Zip drive is outdate. With theExternal HDD you gona have more space than a Zip drive, really much more.
Dec 13, 2010 | Iomega ZIP 250 External ZIP Drive
I need soft ware for a paralle port iomega zip250 i am running windows xp
Go here to download drivers;
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=16736&p_created=1107903170&p_sid=4AwppYXj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00NSw0NSZwX3Byb2RzPTEsMTImcF9jYXRzPTUwJnBfcHY9Mi4xMiZwX2N2PTEuNTAmcF9wYWdlPTE*&p_li=&p_topview=1
Mar 27, 2010 | Iomega ZIP 250 External ZIP Drive
Computer does not recognize usb device - 250 Zip drive Can you help? macdjean@charter.net
Does it recognize other peripherals plugged in? If the usb port is good you have need of drivers for your Zip drive. Or the bad news is, the zip is bad.
Jul 30, 2009 | Iomega ZIP 250 Internal ZIP Drive
Zip 250 disk ejects instantly
mechanicall problem..drive need to be opend....be carfull
Jul 14, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Need driver for PC for Iomega external drive
Try here
http://www.softwarepatch.com/utilities/iomega-zip.html
Jan 14, 2009 | Iomega (11113) Internal ZIP Drive
Want to know polarity of Zip 100 DC power supply.
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Dec 18, 2008 | Iomega U.S. Power Supply Drive
USB 250 zip drive not displayed
Hey, lost connection with you
Thanks,
Ekse
Oct 29, 2008 | Iomega ZIP 250 External ZIP Drive
Where can I find a driver for a Iomega zip 100
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=2012&p_sid=s8_g_w8j&p_lva=1733&prod_lvl1=5&p_prods=5&p_pv=1.5
This has the models with Parallel, Serial, two USB, ATAPI, and IDE Versions, Be sure to choose the right one and The drivers are there
Good Luck
Jul 11, 2008 | Computers & Internet
Iomega (11113) Internal ZIP Drive Logo
191 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
