HP a1620n- Will not startup properly
I turned off my HP Pavilion before it closed down properly. Now when I turn it on it will not come up properly. It cycles between the MS Windows XP screen normally seen at startup, then goes the the HP Invent screen then the the black screen that prompt for normal setup, safe mode, safe mode with networking and Safe mode with command prompt, then back to the intial screen. Can you help me?
  • dpeace1960 Dec 02, 2008
    Thanks for all the assistance. I'm having to perform a full PC Recovery.
    Problem Solver:
  • 10 Answers
The simplest by far is to take the advise jtucker j has given you and tap the f8 button at the black screen.This does take you into safe mode.then it should reload windows files and come to safe mode xp.If neither ones of the advise that was aforementioned has given works, a simple restore from system restore would be easy.Simply go to accessories then system tools then system restore ,if you have files that you have wrote that are needed in the last few days this might not work for you because of loss,if not,at the bottom of the system tools is system restore.click it,go back a few days earlier when your comp was working well and look for a date (it will usually be highlighted or a bit larger in text,click on to select then continue and your comp will reboot and reload windows from the day you choose from a image of that day.then when you do come back up all files and folder will work as they did that day. hope this helps kawuna
Posted on Dec 02, 2008
    Master:
  • 474 Answers
Alright, i can help you.
First, do you have you XP CD?
You will need one, any one, or the instaltion disk that came with it that has the recovery files.
1. put xp disk in cd drive, reboot and boot from CD. You may have to hit F12 to get to the select boot device screen.
2. once the cd boots it should go into the blue winxp install screen and start loading.
3. once its done, press " R" it should be an option for repair.
4. allow system to do its thing and it will go to a command prompt. If it asks for admin password, do so and hit enter.
5. You should now be at the C:\ command prompt. Typ exactly: chkdsk C: /p and hit enter.
It should run a system disk check and repair missing files.
6. once done, type EXIT and hit enter, then when it restarts, remove the disk and when it gets to the black and white asking to choose startup. just hit Enter and it should work fine.
Let me know if it doesnt work and we can try something else.
Posted on Dec 01, 2008
  • 59 Answers
Try starting in safe mode then when it windows starts/full loads shutdown the computer. Then restart the computer-it should start normally.
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
I do not have a printer to download anything,
samsung chromebook manual here
http://static.highspeedbackbone.net/pdf/Chrome%20OS%20User%20Guide.pdf
or hp chromebook here
http://www.shopping.hp.com/shopping/pdf/f2j07aa.pdf
Jun 03, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
How do I get the battery out of my acer laptop
Your Model of Aspire has a different battery release method, see attached pic on how to do it. This is a pic from your User Manual, you can download it from here Download Acer Aspire E1 572
Manual
. I suspect that the information you have been given regarding battery removal and passwords refers to removing the cmos battery as in a PC in the hope that it will clear Bios activated passwords.
May 04, 2014 | Computers & Internet
Www.hp.com/go/techcenter/startup
My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
System temperature (90D)
Apr 08, 2012 | Computers & Internet
Computers & Internet Logo
179 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
