Question about Hess 2007 Monster Truck With Motorcycles
Where are the batteries on the 2007 monster truck located
I have looked and looked and cannot find the batteries to change them. Please help. Thanks, Jack
On the truck, flip it over and unscrew the screw right near the switch for the lights.  On the motorcycles, the battery compartment is behind the front wheel.  put your fingers on both flanges that stick out and pull down (away from the motorcycle).  A lid will pull out.  There are two A76 batteries for each motorcycle.
Posted on Apr 18, 2009
Where is the theft deterrent module location in 2007 GMC Acadia
Look under the passenger side seat. The module is located there.
May 10, 2014 | 2007 GMC Acadia SLE
2007 ducati monster 695 doesn't start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.ducatimonster.org/forums/tech/197818-monster-695-wont-start-dealer-no-help.html
07 695 will not start sometimes
http://kuixihe.com/Downloads/How%20to%20repair%20and%20maintain%20Ducati%20695.pdf
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Apr 07, 2014 | 2007 Ducati Monster 695
How oftem do i need to service my 2007 ducati monster 695? oil change how many miles? can i adjust my clutch?
Hi, Arik332 sorry you can't find the first and best tool you ever bought for your Ducati despair, not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Ducati Monster 695 Workshop Service Repair Manual Parts Download Manuals...
Ducati Maintenance
Ducati Clutch Maintenance Clutch Bleed Flush
Feb 26, 2011 | 2007 Ducati Monster 695
Where is the battery located
hi there are 2 on this vehicle, the main battery is under the passenger seat, and you have an auxiliary battery in the passenger foot well area, hope this helps please vote thanks
May 28, 2010 | 2007 Mercedes-Benz R350
Motorcycle battery seems dead, help locating/replacing/charging
Yes it is the battery. First try charging it with trickle charger. NOT car battery charger. It should work fine once it is charged enough to start the bike. Than the bikes should keep it charged. Or you can jump it with car battery. This is safe. THe motorcyle battery is also 12 volts. Just smaller.
After the bike runs for 5-10 minutes and shut if off. Wait 5-10 minutes after it is off and try again. If it does not start again, than your battery is either dead or your stator/rectifier (your charge system) could be faulty. Lot cheaper to get battery for $30 than to pay $75 hourly shop fees for testing and than repairing.
May 20, 2009 | 2007 Ducati Monster 695
Monster.com resume i made it public how can some body view it
By making your resume public on monster.com, that means it is readily viewed by any "Employer" user who does resume searches in an effort to identify candidates for a position. Keep in mind that this means the person looking for your resume still has to sign in to the monster.com system, and your resume is not instantly viewable to everybody on the whole wide Internet.
For an "Employer" user to specifically search for YOUR resume, they must first log in to monster.com. Following that, this is what the monster.com "Help" segment says:
To find a Resume by its number:
  1. Go to the Resume Search page.
  2. Change Search By Date to From Today to All Resumes.
  3. Enter the Resume Number in the Keyword Search field.
  4. Click Search and the system will locate and display the Resume.
To find a Resume by a Job Seeker's name:
  1. Change Search By Date to From Today to All Resumes.
  2. Enter the Job Seeker's name in the Keyword Search field.
  3. Click Search and the system will locate and display the Resume.
If you are NOT expecting a person to seek YOUR resume specifically, but are simply looking to increase the odds of having your resume viewed for the position you seek, double-check your resume to make sure you included many of the keywords relevant to your desired position (but only if they're *true*!). For example: if you wanted a position in web design, you would include keywords such as XHTML, CSS, JavaScript, etc... If you wanted an Office Assistant position, keywords might include MS Outlook, Lotus Notes, Simply Accounting. "Employer" users typically search for resumes based on keywords relevant to the skills / requirements relevant to the job.
Also, make sure to update your monster.com resume each time there is something new and relevant to add to your resume.
Apr 02, 2009 | Computers & Internet
Hess 2007 Monster Truck with Motorcycles
 the battery compartment is behind the front wheel.  put your fingers on both flanges that stick out and pull down (away from the motorcycle).  A lid will pull out.  There are two A76 batteriesfor each motorcycle.
Dec 26, 2008 | Hess 2007 Monster Truck With Motorcycles
Bike height
I think the 696 is 30" or 31". If it helps, my inseam is 31" inches and I can easily flatfoot it (lots of bend in the knees). It's taller than my 695 for sure--even with the touring seat.
Nov 20, 2008 | 2004 Ducati Monster 800
Hess 2007  Monster Truck With Motorcycles Logo
189 people viewed this question
Top Hess Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hess Toy Expert? Answer questions, earn points and help others
