Question about Toro Lawn Mower With Toro Power Tools
I have a toro ccr 3650 snowblower the electric start just grinds
Could the starter be bad??
Problem just started today
  • dkd1 Jan 17, 2009
    I have the same problem. I haven't taken it a part yet, but I believe the drive portion needs to be replaced as the motor seems to spin just fine. Said another way it doesn't seem to engage with the flywheel....it grinds. Should I consider buying an all new starter (~$132) or just the Drive portion (~$44)? Or are there other recommendations to diagnose this situation further. Thanks.
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Posted on Mar 24, 2009
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
Electric start not working on my toro ccr 3650
go through and check the wiring to see if anything came disconnected
Dec 29, 2012 | Garden
Cannot start Toro 1800 snowblower (electric) inserted key, power connected...
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Jan 12, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Hello, I have a Toro snowblower Model ccr 2450. The starter runs but does not engage to start the engine. Can you tell me how to fix this problem without taking it to a repair shop?
Remove the starter, then check the teeth, if the teeth
are ok, then the throwout Bering is bad, this is the part than pushes out the teeth so it contacts the
flywheel. The parts you need, teeth ,spring, throwout,
show as a kit, but you must buy them from a toro dealer, You need to have your serial #, because the parts are listed by different serial #'s. Now most times you would have to buy the whole starter, but it looks like you can get the kit. If the teeth are bad then the throwout is ok, but you still need the kit to fix your problem.
Feb 14, 2010 | Garden
Where can I get a manual for a toro CCR-3650
go to www.toro.com and should be able print it there.
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Toro Lawn Mower With Toro Power Tools Logo
3,231 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
