Question about Jwin Audio Players & Recorders
Need free repair manual or schematic
Each cassette compartment spring has slipped off. when you open the cassette(s) doors you can see where the springs are suppost to go but i do not know the correct instalation. i need a repair manual or something that shows where and how to replace them correctly.
  • 1314 Answers
SOURCE: I need to replace the Door Springs
if you just need to install springs pull the bottom kickplate can do it there only two screws
Posted on Dec 30, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Posted on Dec 10, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
jsrock516
  • 5911 Answers
SOURCE: how to install spring clamp on outer portion of
If you are referring to the small wire hoop with the small spring, follow these steps:
1. Make sure the bellow is installed correctly all the way around the opening of the door frame.
2. Beginning at the top of the door, start inserting the wire hoop in the rubber groove of the bellow. Make sure the wire spring points towards the 6 o'clock position (bottom).
3. As you work your way around the door to the 4 and 8 o'clock positions with your hands, maintain some constant downward pressure to hold the bellow in the rubber groove.
4. Pull the spring apart to stretch the wire hoop open and snap it back into place.
NOTE: Using a second set of hands to hold the wire hoop in place, makes the process much easier.
If you still have problems, please let me know. I hope this helps you.
Posted on Jan 05, 2010
Testimonial: "Clear, detailed, helpful instructions. Many thanks."
daves944
  • 1050 Answers
SOURCE: Front right coil spring has slipped below spring
This usually happens when the spring has broken. You'll have to remove the upper 3 nuts that hold the strut mount to the body, and the bolt that goes through the lower control arm that mounts the strut, also the sway bar end link, then remove the spring and strut as an assembly. You'll need a spring compressor to safely remove and install the new spring. It is always recommended that you replace the front springs as a pair (both side). This job may be better left to a pro unless you have some experience, also you may be able to buy a product called "quickstruts" They are sold as a spring and strut completed assembly so you won't require a spring compressor.
Hope this helps,
Dave
Posted on Aug 16, 2010
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Canon Mini DV MV530i: When the cover is fully opened (while holding the button) the cassette is not ejected from the cassette compartment whilst the "EJECT" word blinks in red on the screen. The user...
Tape mechanism problems are quite complicated but they can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 04, 2010 | Canon MV530i Mini DV Digital Camcorder
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
I have a 1997 ims dodge caravan handicapvan where the door will not open all the time to lower the ramp. you have to push the door latch slightly just to release the door. the ims door latch seems to move...
Are the springs in the door latch bent or the contacts on the end missing?
Easy fix is to get new springs or put new contacts on the end of the springs, such as a non-corrosive screw.
Dec 12, 2009 | Dodge Caravan Cars & Trucks
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Dec 10, 2008 | TDK TC-30HG VHS-C Tape
Cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Apr 23, 2008 | Cameras
Jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
the switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Aug 18, 2006 | JVC HR-S9500 S-VHS VCR
Top Jwin Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
