Question about Car Audio & Video
Install Aftermarket Stereo in 1998 Mercury Sable
Hello all,
I need to find a way to install a newer stereo in my 1998 Mercury Sable. I currently have a radio with a tape player. With the new age, I would love to have a newer stereo and maybe even be able to plug in my iPod.
  • 22 Answers
You need to buy a radio from Best Buy or somewhere. Installing on a Sable is not easy because your radio face plate is in the front but the tuner itself is located in the trunk and you need to run wires from the dash to the trunk. You need to buy a radio and $80 parts kit, but I promise it is not an easy install unless you are familiar with car audio and running wires through cars.
Posted on Dec 04, 2008
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Installing aftermarket stereo
Should just need the New stereo and the items that come in the box with it.
Sep 06, 2013 | Acura Cars & Trucks
Do I need a wiring addaptor to install this stereo into my 2004 f150?
Yes, I recommend a vehicle specific wiring harness for the installation to be proper. When installing aftermarket stereo units in some vehciles, it is necessary to insure that all of the vehicles components are receiving power during normal operation.
FYI, to obtain the proper harness, you will need to provide a bit more information about your vehicle, such as 2 door or 4 door, what version of the Ford stereo is currently installed and whether or not the unit amplified.
Mar 08, 2011 | Clarion NX500 Car Video Player
My radio has all the bells and whistles. It is a large square box that an aftermarket radio will not fill. It seems to have no reception at all. when it gets warm it starts to recive but very weakly. ...
A used one will work, you can get the code at the dealer. As for aftermarket radios: standard aftermarket radio size is referred to as 1 din. Your stock stereo is 1.5 din. To install an aftermarket stereo in Amy car requires an install kit, in your case the kit will make up for the size difference by just filling the gap with black plastic. But there are aftermarket stereos that are 1.5 din. They will still require an install kit, but will completely fill the hole in your dash. If you're planning on getting a $99 stereo at a parts store don't bother and just find a stock one. But spend $150 on an aftermarket stereo and you'll be very happy. Good luck.
Mar 06, 2011 | 1998 Oldsmobile Cutlass
Changed my factory stereo with an after market stereo and now truck wont start what do i need to do or what didnt i di its a 1998 ford ranger xlt
put back the factory stereo if the car works then you have a model that depends on that head unite you will need to use a factory stereo by pass harness to solve this problem when you install you after market unite.this is a common issue with newer factory stereo's if putting back your factory stereo does not fix this then check all your fuse's generly there are more then one fuse box in newer cars
Mar 18, 2010 | Car Audio & Video
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 02, 2009 | 2003 Mercury Sable
Upgrade Mercury Sable 1998 headlights
Most of the time it's not the light bulb, but the lens get dull and end up getting oxidation do to being out in the eliments. You can buy product's at Wal Mart in there automative section that will bring them back to new condition, or a good wax if there not to far gone will fix them too. good luck and hope this helps
Apr 08, 2009 | 1998 Mercury Sable
Need a stereo wiring diagram for my van.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mercury.html
here is wiring information for you I found it for me to use with the same problem.
Mar 27, 2009 | 1993 Mercury Villager
Car Audio & Video Logo
1,057 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
