Question about Samsung Yepp YP-T7JX MP3 Player
When i open my record soud on my pc in Voice yepp Player, Display menu "Header information ERROR"
Hi Please help me. When i open my record soud on my pc in Voice yepp Player, Display menu "Header information ERROR", i copy this file to samsung , but it's display "NO VOICE" however the total file is 01 in one folder. plase help me. my record file is very important for me. what can i do?
  • 58 Answers
Known problem. Try download new firmware and it will star regognising it!!
Posted on Sep 01, 2007
  • Marios Kyriakou
    Marios Kyriakou Sep 01, 2007
    And something else. Try VLC player. IT REALLY WORKS
  • Marios Kyriakou
    Marios Kyriakou Sep 02, 2007
    Me again. ALSO Try to take it out from that folder and put it somewhere alone with out a folder..!!
SOURCE:
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
Files will not transfer to PC or play when attached to PC
Hi have you installed the correct software for your device
Dec 06, 2007 | Olympus WS-100 Digital Voice Recorder
I had recorded voice in PHILIPS (SAXX )which have been stored int the Recordings Library. But when i want to hear, i find a reply the " file format not supported". What to do to hear the voice...
If you connect your player to the PC and select your device in Windows Explorer you should find a "Voice" folder that contains your recordings. The files are named as voicexxx.wav and you can simply copy and paste them to the PC.
If you have problem with this and want to get additional help please define the exact type of your player because almost all the types of gogear are SAxx .
Thanks
gylacz
Apr 29, 2011 | Audio Players & Recorders
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
How do you retrieve corrupted files on a DS-3300
If the files are corrupt then you could only retrieve corrupted files which would be useless.
Sorry.
Feb 24, 2009 | Olympus DS-3000 Digital Voice Recorder
Lost instruction
ok lamar230990 to turn your mp3 player to msc mode disconnect it from the computer and turn it on. once it is on go to settings and scroll down to protocol and click on it with the play/pause button. this should turn it to msc mode then connect back in to the computer and go to this site to download the software www.rcaaudiovideo.com
Oct 22, 2008 | RCA M4204 MP3 Player
File check error in
my iriver t20 shows on display "file check error" and all my folder are disappeared.please help me to solve the problem. thanks for your assistant.
Dec 14, 2007 | iRiver T20 MP3 Player
Recorded voice files
Of course, first you need to transfer those recordings from your mp3 to your computer. Then open up whatever cd burning software you use, choose make audio cd, click add files and choose your recordings and burn. L8R
Sep 17, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T7JX MP3 Player Logo
170 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
