LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Problem for LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Not made a back up, LaCie Hard drive, USB 2.0
By suahgonzakle on Dec 01, 2008
my last computer was xp and was broken , i get one with vista.
I tray to made a back up and said: QBB is not a valid win32 application. How can I get this information?
Thanks for your help
Solution #1
posted on Mar 12, 2009
Not Rated)
ggalways88
Rank: Master
Rating: 78%, 9 votes
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Comments:
Mar 12, 2009
- To correct and solve this error, follow this steps:
Was this helpful?
Yes
No
Popular Solutions for LaCie External USB 2.0 500GB
Questions and Unsolved Problems for LaCie External USB 2.0 500GB
Do you recommend LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive?
Answer
Answer
I have a Lacie 2 Big Quadra. I can see them under device manager, but not disk management. I need to... (More)
Answer
I have a Lacie external usb 2.0 hard drive that i used on an old XP machine. My Vista computer will... (More)
Answer
My computer does not recognize the external hard drive month ago I dont have any problem with it
Answer
During this days the external hard drive is on but my computer does not recognize
Answer
I can copy files to my LaCie 160GB Brick from my PC just fine, but I can't seem to open them from... (More)
Describe your Hard Drives problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
in , PA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
