Question about HP vp6320 Multimedia Projector
HP vp6320 projector ten seconds it shuts off
When I turn on the projector at ten seconds it stops sits there and flickers a bit then shuts off. I work for a school district and we have alot of these projectors I have not seen this problem happen once in the 2 years I have worked with them.
I had the same problem, the first couple of replacement bulbs i ordered worked fine but the last 3 i got, 2 of them have been faulty, i just sent them back and they replaced them. If its too late to send the bulb back you can go to the settings on projector, select lampsaver setting, its probably set at off, turn it on. Your bulb will be a little dimmer in this setting but shoud let the projector run ok.
Posted on Mar 09, 2009
Tip
Replace HP VP6321 Projector Lamp Models: HP VP6321 / HP VP6320 / HP VP6310 / HP...
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
on Apr 23, 2010 | HP vp6320 Multimedia Projector
Tip
HP VP6321 Projector Manual Download
Download HP VP6321 Projector Manual
Have you misplaced your HP VP6321 Projector Owners Manual?
Would you like a digital, searchable, pdf version of the HP VP6321 Projector Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
HDCP compatible
There is no fix to this. basically HP did not make the HDCP very robust. It will DHCP with some DVD players, not all. HP is calling this a computer projector and down play the issue. No fix, try different DVD players. I had good luck with Toshiba HD.
Jan 05, 2009 | HP vp6320 Multimedia Projector
HP vp6320 projector
You need to replace the color wheel sensor. I can fix it.
Dec 01, 2008 | HP vp6320 Multimedia Projector
Making the projector widescreen
VP6320 is not a wide screen projector. It is formatted for 4X3. If you send 16X9, it will crop part of the picture.
Aug 25, 2008 | HP vp6320 Multimedia Projector
Hp vp6320
For sure this is caused by failed color wheel sensor. HP redesigned this assembly twice and the last design change worked very wheel. The new sensor assembly comes with new temperature sensor cable, focusing spacer. I am factory trained and I can repair the projector for you.
Apr 11, 2008 | HP vp6320 Multimedia Projector
Hp projector
This is caused by the color wheel sensor failure. The sensor is mounted very near the lamp and suffered extreme temperature. This problem can be corrected by installing the redesigned color wheel sensor. You also need to refocus the sensor due to different focal length. HP also recommended to replace the temp sensor cable. If you still have the projector, I can fix the problem for you.
Jan 08, 2008 | HP vp6320 Multimedia Projector
HP vp6320 Multimedia Projector Logo
391 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
