Question about Fuji FinePix A345 Digital Camera
Fuji finepix a345 file size is too large.
If I take a picture with the quality set at 3:2, the average file size is almost 900 KB. If I then open the picture with Microsoft paint and then re-save it the file size goes to 180 KB. There appears to be no difference between the two pictures other than the file size. Is there a way to set the camera to do this so I don't have to convert all the pictures manually?
SOURCE: Zoom Error
I concur with rogerstone1's reply. I just replied to another post with similar information and will repost here to make sure you get the info. Don't know of a repair manual, but found the owners manual at this address:
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=833654&prodcat=829284&sscucatid=664271
Reposted reply:
I have the same camera (Fuji Finepix 345) and a problem that may have been similar. When I powered on the camera the lens would extend but as soon as I attempted to take a picture the camera lens would retract and the camera powered itself off.
The camera is now working. I followed the troubleshooting steps at this address:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Gently holding onto the lens to prevent it from retracting during power off was the solution that worked for me.
My camera's problem seemed to slowly get worse over time until it finally stopped taking pictures. At first my wife and I noticed that pictures were sometimes out of focus. It turned out that my wife takes pictures using the viewfinder where I use the LCD screen. She wouldn't notice that pictures were out of focus. If I saw that the LCD was out of focus I'd power cycle, press the zoom button to get the lens to move, and/or try tapping the camera while holding it upside down and powering it on. Eventually it got so bad that we couldn't get any pictures in focus and I ended up buying a different camera. Then last night I tried the trick about holding the lens and the camera is working again.
I suggest you first see if the camera will power on when switched into playback (picture review) mode. Move the slider to the playback position and turn on the camera. Can you review pictures? If not, then clean the battery contacts by rubbing them with a pencil eraser and replace the batteries. Try holding the power button down for several seconds, it seems like my camera is slow to power on sometimes.
If you can review pictures in playback mode you'll know the problem is not batteries, battery contacts, or the LCD display and circuitry. Is the lens stuck? To jar it free, try holding the camera upside down and tapping the edge against the palm of your other hand while holding the power button down. As mentioned earlier, this used to work for me.
Posted on Dec 31, 2007
cammedic
  • 667 Answers
SOURCE: Fuji FinePix A345 Shutter Button
I have one. Its used but in good condition. I use the same name as I do here on hotmail.
Posted on Jan 05, 2008
  • 198 Answers
SOURCE: can't download pictures from camera
perhaps your Fuji download program is corrupted, or your cable has been broken. Most computers now have a direct plug-in for your memory card, as well as plenty of built-in programs to download your pictures. I like the Vista Photo Gallery (come to think of it, it is the ONLY thing I like about Vista. At any rate, unplug your xD chip from the battery compartment (you can just pull it out, or push it and it pops up), (and close the battery compartment, or you will have to reset the date and time), plug it into your computer, and wait for a bunch of programs to pop up eager to download your photos. If that doesn't work, you may have a bad chip--but if you had a bad chip, you couldn't view your pictures on your camera. If you have XP, you should be able to see the xD as a new drive if you plug it in--not sure which programs will pop up, but you may be able to move the pix just like any files from one drive to another. Good luck. Incidentally, if you need a new cable, internet charges range from 3 to $25.
Posted on Jan 21, 2008
cammedic
  • 667 Answers
SOURCE: Webcam a345
You need the USB cable to connect the camera to your computer and in the setup menu, change your USB mode to PC
Posted on Feb 03, 2008
SOURCE: problem with fuji finepix f460 digital camera
cgfjk
Posted on Feb 20, 2008
Hello, My camera had been taking photos under a file size of 1 MB, normally 800 KB. Today for some inexplicable reason (I must have done something!), the photo file size is 4MB, too large to send and use...
On your camera, look for settings. You must have set it on "Large" or "Max" picture quality. Thus making your 'normal' 800kb into a more better quality.
On your laptop/computer try to open it in a image editor and change the resolution of the picture.
Dec 14, 2010 | Sony Cybershot DSC-T200 Digital Camera
QUALITY UP TO 10 FRAMES ONLY. I CANNOT TAKE MORE THAN 10 PICTURES.
What memory card are you using? I think even a 16mb xd card should hold more than that when the camera is on its highest quality setting. I'll check mine out and let you know. Dave
Apr 12, 2009 | Fuji FinePix A345 Digital Camera
FINEPIX A345 SOFTWARE DOES NOT WORK.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 13, 2008 | Fuji FinePix A345 Digital Camera
Emailing Video taken on a FinePix A800
Hi!
It's possible that the video file you are sending is too large. A few seconds of video from your camera will already be in a few megabytes (assuming that the camera is set to high resolution). How large is the file?
For smaller file size of video from your camera, you can lower the frame size. Here's how you do it:
If you are planning to send the file via email - select a lower quality.
I hope that helps.
Have a nice day!
Apr 15, 2008 | Fuji FinePix A800 Digital Camera
A345 finepix viewer
images obtained from the Fuji FinePix Pro S1 digital camera that are saved as TIFF-YC (also called Tagged Image File Format YCbCr or Yb). TIFF files cannot be opened with any of the programs that are native to WinXP, other Microsoft imaging programs, or most third-party software. The TIFF-YC format is antiquated and you should avoid it. Instead, save images as JPEGs (Joint Photographic Experts Group) or some other format.
YOu shoUld save the file in another format.
Mar 14, 2008 | Fuji FinePix A345 Digital Camera
Pictures cannot be download
When you try to transfer a large number of files (or a single large file) from a PTP (Picture Transfer Protocol) device, such as a Sony Memory Stick, you may receive an error message saying that your computer cannot detect your camera or that, although it has detected the camera, the current picture cannot be copied. This happens because in older versions of WinXP the PTP driver limits file transfer to 2,048 files at one time and those files must be less than 210MB. If you update WinXP with Microsoft's latest service pack you should eliminate the problem.
Feb 22, 2008 | Fuji FinePix A345 Digital Camera
Change Resolution
Okay this file size is very small and even if you could chage the settings on your camera to the lowest , I'm sure the filesaize will still eb too large.
What to do is use a photo editing program such as adobe or maybe even something else you can get for free. when saving the image you will be able to enter the image size or select what quility, the lower the quality the lower the file size.
To check the file size of an image just right click on it and go down to properties, remember 1mb is equal to 1024kb
Hope this helps
SE0 Consultants - SEO Optimisaton
Dec 03, 2007 | Fuji FinePix A350 Digital Camera
FinePix A345
Get the images off the card. Plug to your computer and download them. Then reformat the card in the Camera. If your computer is a Windows ME/2000/XP/Vista you will not need any extra software to do this. Windows can do it all by its self.
Sep 30, 2007 | Fuji FinePix A345 Digital Camera
Fuji a345
Simply wear and tear.- dirt ingression- damage from a knock- nothing you can do about unless you are a watchmaker. A repair will be as costly as simply replacing it Check out Fuji support though to be sure.
Aug 15, 2007 | Fuji FinePix A345 Digital Camera
What is the procedure for sending pictures over the Internet in FinePixViewer?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer". Changing the size of an image file 1. Start up the Viewer and select the folder containing the image you wish to send. 2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window. 3. Select "Image size" in the "Image" menu. 4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button. 5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Fuji FinePix A345 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
