T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
I find the machine type riso rn 2050, there is the problem of cod t4-513 I tried to solve the problem is that I did I Mchadi in the problem and guide you
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
A T3 error code is indication of some kind of problem associated with the clamping mechanism. Most of the time, what happens is that there is a magnet attached to a flag on the rear side of the drum and it has fallen out of place. If you can find the magnet, reattach it with a strong adhesive. Check for smooth operation of the clamp by hand as well and lubricate if necessary.
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
t3 error on riso GR 3770
