Question about Milwaukee Tool Audio Players & Recorders
Doesn't work I have a Milwaukee radio that will only work on battery power. Is there a fuse that can be replaced or should I assume power supply is fried?
2 Suggested Answers
sharcnet
  • 2124 Answers
SOURCE: Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Posted on Jan 24, 2008
SOURCE: milwaukee job site radio
You probably need part number 23-81-0545. I just bought one from ToolsForLess.com, but plugging that part number into a search engine will return plenty of other people who sell that part.
From the Milwaukee web site, the link below has the schematics on the 120v radio sold in the US. Note, this is for Milwaukee Job Site Radio, item 49-24-0280 where the serial number starts with A81A. There are other schematics on their site if this isn't exactly your radio.
http://www.milwaukeetool.com/CMS/Diagrams/54-49-0210.pdf
At the bottom of that document, page 2, you see the following troubleshooting instructions (good luck!):
BASIC TROUBLESHOOTING
NOTE: Before opening the unit or soldering, disconnect ALL power sources. Turn
the power switch "on" momentarily to discharge stored energy.
***** Radio operates on DC but not on AC:
1. Plug in radio and using a voltmeter, check for DC voltage across items #14
and #15 shown on the wiring diagram. (Approx. 15-22 Vdc).
2. If there is no voltage, change the Transformer Assembly (23-81-0545).
3. If voltage is present, continue to "All other electrical issues" shown below.
***** All other electrical issues
1. Disconnect the LCD Assembly (22-09-1575) from the Speaker PCB
Assembly (22-09-1548) by disconnecting items #11, #13 and #20 on the
wiring diagram.
2. Plug a new LCD Assembly into the Speaker PCB Assembly and check for
proper operation.
3. If the radio works, the LCD Assembly is bad. If the radio still does not
function correctly, replace the Speaker PCB Assembly or Volume Control
Switch.
Posted on Sep 19, 2009
I have a milwaukee jobsite radio that won't take a charge what could be the problem
The rechargeable battery needs replacing. But check that there is power at the end of the charge lead.
Feb 01, 2016 | Milwaukee Drills
MILWAUKEE JOBSITE RADIO'S CLOCK DISPLAY WORKS BUT NO RADIO
if it work on battery and didnt work on 120 volt,the transformer is dead,i see a lot of radio with dead transformer.
if it dont work with battery and 120v,the control board have problem.
Oct 18, 2012 | Milwaukee Tool 49-24-0200 AM/FM Radio
Job site radio work turn on seems there is no power going to radio. When plug in there is no sign of power in the radio. I have replaced the cord end and that didn't help.Any ideas?
probably the transformer, if it works on the battery but not plugged in thats the most likely cause. I have the same problem and will repost if the transformer replacement works. Cheers
Oct 02, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
My 2000 Toyota LE wouldn't start one day, so I got it jumped and took it for a drive to charge the battery. While at a red light, my car stalled out and died in the middle of the road. I got it to a...
probably a fuse, unless its an aftermarket radio that lost complete memory mode, and need to be re coded to work. the easiest way to check this is to look for the power wire, on your car its a blue wire with a yellow stripe for the battery one, and a gray wire for the ignition one that supply the radio with 12 volts, see if they have power,
Jul 22, 2011 | 2000 Toyota Camry
Radio windows and fuel read out stopped working
Check Fuse 2.3 (20 Amp). See electrical diagram below.
When it goes, it'll take out the audio and "Cluster and Panel Illumination."
(assuming your vehicle doesn't have an OEM Nav system - in which case fuse 2.3 would
supply power to the Nav system).
Fuse 2.3 is located in the CJB (Central Junction Box) - not the BJB (Battery Junction Box),
nor the AJB (Auxiliary Junction Box).
Also, check fuses F1.6 (60 Amp), and fuse F1.62 (30 Amp) in BJB (Battery Junction Box).
Also, check fuse F2.17 (15 Amp) and the "Accessory Delay Relay," both in the CJB (Central
Junction Box).
Here's the electrical diagram for 2005 Mercury Mountaineer Power Windows:
Note how fuses F1.6, F1.62, F2.17, and 'Accessory Delay Relay" will all
disable the power windows.
May 13, 2011 | 2005 Mercury Mountaineer
Milwaukee jobsite radio just stopped working - it was plugged in, working fine and then just stopped. Any ideas on how to fix it?
If you are an apprentice, make sure that one of your colleagues didn't cut the power to it. :>)
Then ask a sparky to check for power at the radio itself.
If you have power, then you will be looking on the back for a fuse, and if nothing there, opening it up to see if there is an internal fuse or evidence of a short circuit or something burning out.
Jan 20, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
My milwaukee radio just quite working ? why ?
may be there is something wrong with the male end you plug into the wall or the cord itself
Aug 20, 2010 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
I have a 2001 f-150 the radio doesn,t work,i bought a used one off ebay,i also checked the fuses,still nothing
which fuse did you replace... the radio uses three!
you need to check fuse # 1, #8 and #20 in the CJB (central junction box) under the dash
assuming these are good then pull the radio out again and check for power at the radio pins number 3, 9 and 10
assuming these are good check your ground while you are there....use the test light with the good poser at the radio pin # 10 and then ground at the radio pins #2, 11 and 16
Mar 25, 2010 | 2005 Ford F-150
Questions:
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Milwaukee job site radio
The transformer needs to be replaced. 120VAC to 15VAC. Take a look on amazon for it, here: Amazon com 15VAC transformers. Wish you best of luck.
Brust
Dec 02, 2007 | GE Superadio III AM/FM
Top Milwaukee Tool Audio Players & Recorders Experts
k24674
Andrew Taylor
Andrew Taylor
Are you a Milwaukee Tool Audio Player and Recorder Expert? Answer questions, earn points and help others
