Question about Pentax Optio 430RS Digital Camera
My Optio won't stay powered on.
When I press the on/off button the screen lights uo and displays PENTAX, the lens zooms out but it gets to the end of it's travel and it sounds like a safety device is preventing damage by slipping the gears for a second then it zooms in again and shuts down. It seem like whatever limits lens travel is not set correctly. I've had a look inside but I cant see any stripped gears or broken/loose parts. Has anybody else experience of this ?
    Novelist:
  • 107 Answers
This is probably due to a broken sensor tab inside the lens, or a failed sensor. When the lens reaches the end of its travel a small plastic tab will pass between the ends of a C shaped sensor and let the camera know the lens has reached the end of its travel. You are not hearing a safety device, you are hearing the gears actually slipping. Don't let it do that too much or you will turn one problem into two problems quite quickly. If you cant find the broken part it will require professional repair. I would advise against taking the lens assembly apart. They are extremely hard to get back together and you very well may end up with a junk camera. David Millier Advance Camera Repair
Posted on Feb 24, 2007
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Nov 09, 2014 | Pentax Optio Cameras
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Camera problem
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Hi drdaved It seems to be a battery cotact problem. The battery contact pins might have some rust. Try to clean them with a rubber and alcohol (after the rubber)
Dec 03, 2007 | Cameras
Lens Jammed
Is looks like a problem with the zooming mechanism. Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 12, 2007 | Pentax Optio T10 Digital Camera
Pentax Optio 430RS Digital Camera Logo
152 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
