Question about Holmes Products HFH111TU Compact Heater
Heater wont blow hot air anymore.
Our heater HFH111 will no longer blow hot air. We tried unplugging it for a while and plugged it back in but that didn't work. Please help.
  • Anonymous Mar 27, 2014
    i have a New Air AH 450
    When I turn on every light is working except there is no hot air coming out
  • 706 Answers
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Posted on Dec 02, 2008
How can I fix this my van only blows out cold air?
Check both hoses to heater core and see if they are both hot. If not, try back-flushing heater core. If the are both hot, you may have an air"blend" door not working due to bad actuator or vacuum leak. This is the door which changes hot the air flows into the heater core or not.
Mar 02, 2015 | Cars & Trucks
2002 Ford Taurus, Heater blows cold air?
What have you checked so far ?
Radiator full of coolant ? Heater hoses getting hot ?
Feb 23, 2015 | 2002 Ford Taurus
how old is the thermostat? are any hoses cracked or sucked together. heater core may need to be flushed or replaced? good luck!
Oct 20, 2013 | 1994 Ford Ranger Supercab
Why wont the heater blow out hot air in my 1995 pontiac bonneville. it will only blow cool air
If the heater hoses are getting hot, the problem may be a faulty blend door under the dash. The blend doors direct air thru the heater core and the vents.
Oct 12, 2012 | 1995 Pontiac Bonneville
Fans are blowin cold air but wont blow hot air
needs to replace the heater core
Apr 25, 2012 | Cars & Trucks
Heater wont blow hot air...new thermostat 1998
is the heater tap working to let water through the heater core it may not be opening have to check operation of that
Oct 25, 2009 | Ford Taurus Cars & Trucks
Ford ka heater blows hot air all the time
Taurus does not use a heater control valve. It runs coolant thru the heater core constantly. You may have a temp blend door actuator problem or a plugged up heater core is also very common. Feel the heater hoses, they should both be very hot, it one is much cooler; you can try to back flush the core.
Mar 26, 2009 | 1999 Ford Taurus
Heater wont get hot
it has a valve on the heater hoses on one hose that has a vacuum line running to it check both sides of the hose on each side of the valve if its hot both sides its ok. Then check to see if both hoses are hot this will mean that the water is flowing ok if its not reverse the hoses on the heater core somehow it will flush the core out. If this is all working then its the door on you heater box not closing the air conditioning hole off . It goes through the same vents as heater
Dec 16, 2008 | 1998 Dodge Ram 1500 4WD
Holmes Products HFH111TU Compact Heater Logo
397 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
