Question about Microsoft Xbox 360 Console
Problem connecting to net
I use a cable hooked to rca cable box to go on internet but its not responding it says net work adapter is disconected. When i hook it straight to computer port the network adapter works but the xbox does not reconize my ip address.
  • 72 Answers
If you run your console through a router/gateway/switch it will resolve this issue and save a alot of heart ache.
Posted on Dec 02, 2008
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . :
Subnet Mask . . . . . . . . . . . :
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Disconecting from internet, working so slow
check the internet connection and try to plug in cable and check if the problems persists..
Jul 07, 2009 | Linksys StackPro II 100BaseFX Distance...
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Phase linear uv8
Assuming that your unit have a rear video/audio input, you need an adapter cable. 35mm to video/audio rca. You may find one on Ebay or RadioShack. Goodluck.
Jan 28, 2008 | Lanzar SVD26MUT Car DVD Player
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Trying to connect my xbox
hook it up in place of the cable box...rf adapter or use the rca plugs and get barrel adapters to connect them
Oct 30, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
