Question about Audiovox CDM8910WW
Display isn't working at all
Well i was running on a treadmill and i had my fone sitting on top of it and it fell off and when i picked it up the display wasn't working but it turns on. and the little green or red light at the top still works and if i press the lcd cord just right the screen lights up for a lil bit. my dad is ticked so could u pleez help me
  • 65 Answers
Maybe the Lcd connector (flex cable interface) was disconnected if you can open it just press it hard.
Posted on Jul 05, 2007
HOW DO WE PICK THE BEST TREADMILL?
When you want to pick up the best treadmill, you will definitely fall into a maze. So how you pick the best treadmill? The use of the best treadmill varies from user to user. What we mean is that not all users have the same requirements for using a treadmill. For example, beginner treadmill users may have one type requirement. They may want a regular running exercise and want to burn a few calories quickly.Click here for Best Treadmill reviews.
Jun 05, 2018 | Best Exercise & Fitness
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
My t101 treadmill is not working, when you switch it on it does the normal checks then sits at P0, when you try quick start it just moves you through the "time" then the distance then the...
YOU MUST ADJUST THE SPEED SENSOR +reed switch sensor
Tight the flexible cable from keypanel vs display board and then tight the connector from display board and lower board.
See the block diagram.
You will have 3 options:
see the block diagram
12_1_2011_4_38_18_pm.giffINALLY YOU WILL 2 OPTIONS: A) DISPLAY BOARD FAULTY B) MAIN MOTOR CONTROLLER BOARD.
SINCERELY.
Sep 29, 2011 | York Barbell Home Use Fold-Up Treadmill
I have a t9450 treadmill and have adjusted tension on belt. It now makes a loud noise when I run. The belt isn't slipping and everything else works. Noise is loud and annoying. Can't run on it....
hi,
Try to lubricate the running belt. If the lubrication is not proper then the belt will make noise. You have to use silicon lubrican for the same . Watch the following video to know how to lubricat the treadmill.
OK
Aug 23, 2011 | Exercise & Fitness
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Audiovox CDM8910WW Logo
106 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
