Question about Lexmark Office Equipment & Supplies
The computer keeps telling me that the printer is open however it is closed. What to do?
    Sergeant:
  • 291 Answers
Uninstall the printer driver and then reinstall it with the printer driver installation cd.it will then work properly .
Posted on Dec 01, 2008
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
My BMW 1 series keeps saying the bonnet is open when its not, and the alarm keeps flashing up on the dash. Any help?.
Check the bonnet pin (small switch that is pushed in and out by the bonnet opening and closing) which tells the computer if the bonnet is open or close, maybe its faulty or broken and the computer thinks the open is always open even though its closed.
Sep 29, 2011 | 2008 BMW 1 Series
My lexmark z1320 will not switch on right. the light just keeps flashing and my computer not picking up device. it was working 24hrs before and no one has used it since. can you please tell me what the...
The flashing of the lights could mean paper jam, alignment problem, ink level low warning. Try to disconnect the printer from your computer. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the printer cover. Reconnect the printer into your computer. Make sure ink levels are substantial for printing. Try to print again.
May 15, 2011 | Lexmark Z1320 InkJet Printer
Keeps telling me to close upper side panel but nothing is open? we moved copier to onther location and now on the led screen it reads close upper side panel but I cant see anything open and it wont copy
I presume you have removed and reinstalled the upper side panel ... ???
Make sure all the levers and switches that are suppose to tell the copier that the panel is closed are closed.
If you have enough fingers, you might try to close all those switches manually. Secondly, you can test those switches if you can access them.
Otherwise, it is time to call the copier guy to fix.
Dec 30, 2009 | Toshiba DP2570 Printer
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Apr 24, 2009 | Office Equipment & Supplies
I have a Brother MFC-7220 USB printer. It keeps telling me that the back cover is open ... and it is closed. Now I cannot use it. lease help. Thanks.
hte back cover has a little micro switch.
open the back cover, make sure there is nothing preventing from closing tight. close the back cover tight. if you have to, use tape to secure it.
Feb 11, 2009 | Brother Office Equipment & Supplies
The Error says "Cover Open Front" but it is not open
Most printers have a plastic pin on all of the covers that pushes a switch when it is closed. This then sends a signal to the printer telling it "I'm closed".
Probably the pin is broken off (quite by accident I'm sure). A solution is to push a piece of paper in the hole where the pin is, closing the switch, to fool the printer into thinking that the cover is closed. You can try this by pushing a pen point into the hole to see if the message goes out. (Don't forget to remove the paper when you open the cover. The switch is there to keep things out of the mechanism while it is running. May not hurt you but will damage the printer mechanics irreparably.)
Anything else is an error with the printer software and processor and can't be fixed easily.
Sep 02, 2008 | Konica Minolta Magicolor 2530 DL Laser...
My printer keeps saying Cover Open and won't let me do anything else
Hi All printers have a protruding piece of plastic on the cover / lid, when out of place it tells the printer the cover is open
When you close lid it is inserted into main frame which tells the printer that the lid is closed.
Look for this it may be damaged. If so roll a small piece of paper and insert ito the recepticle hole.
It will trick printer that the lid is now closed.
You will need to remove it each time you need to change inks etc...
Good Luck!
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark Office Equipment & Supplies
My printer keeps telling my door open,,and its not its very closed
your printers door closing switch is having problem you have to open the printer and check for any broken or dislodge part
Please help
first install it at another computer and check if problem persists (if not - is a driver problem) icq 475653626
Nov 27, 2007 | Samsung ML-2510 Laser Printer
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
