Need new signal circuit board for my TV
26'' Pyrod PW 2602 TV Serial 00106
Circuit board details: CX30 DG26
B.05.3544.11A
Serial CX050657166
  • sbriggs2 May 06, 2009
    need new power cord circuit board
Amigaman
  • 248 Answers
SOURCE: Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Posted on Nov 11, 2007
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 24, 2007
SOURCE: Circuit board diagram for Sony TV Model no. KV-T25SZ8 Serial no.1015982
no power standby & no sound
Posted on Feb 18, 2008
DOCTOR VIDEO
  • 131 Answers
SOURCE: REPLACE BOARD ON MODEL L26WD21
the part store is the best has a world wide search.www.part store.com . The part number is located on the board itself . You could call them give them model number and ask them what boards are aviable for that tv , and take those parts and see if the numbers are on any of the board.
these board are not cheap 150 dollars to 350
thanks doctor video
Posted on May 12, 2008
freetek
  • 5568 Answers
SOURCE: Protron LCD TV Circuit board
Just posted this elsewhere:
 I checked and found the Protron name belong(s) or (ed) to Spectroniq and neither of the two websites are up anymore.
Also, I could probably make a zapped supply work again but you do not know what might have been damaged downstream from it and that is a good possibility; the damage may be much deeper than it appears since many of the integrated circuits used in modern equipment don't tolerate hundred (or thousand) volt spikes and without a working supply, there is little chance of diagnosing it unless a service department has a few lab-type power supplies and can simulate the failed original supply.
If you do find anyone who has stock on assemblies for this TV, you may find more than one part number on the board. If it is a number that seems to be under clear lacquer, it is likely only the bare board number. If it seems to be stamped on or has a label with a number on it, this is going to be the whole part number for the 'stuffed' board.
I can't help you with this one but I would suggest, especially if you live in a lightning-prone area to consider installing a 'whole house' surge protector. They do cost a couple of hundred US dollars plus installation charges, but the established companies even include an insurance policy that covers $10,000-25,000 in damages. If you own your home, it's your decision and I cannot imagine any landlord would object to having you install one at your own expense.
Posted on Sep 28, 2008
Wondering if its my main board on my hdtv flat screen. it comes on normal for about 10 to 15 seconds then i lose video but not audio
sounds like a failing t-con board. this board is on the back of the screen controls the signals to the screen. ribbon from main board goes to the t-con board.
Jan 28, 2017 | Westinghouse Televison & Video
Devant TV suddenly shows no picture or black screen but the power is on (red)? I tried turning on the TV by using the remote or the butons at TV but stilnothing hapened using Air for the signal source
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 03, 2016 | Televison & Video
Where do i find a new circuit board 2008 26 in. 720 p hd lcd
try to contact the service center because they might have the exact parts you may need if replacement parts will be issued to you it might not work properly.
Oct 14, 2010 | Element Electronics 26 in. LCD TV
I plugged in my sanyo 26" lcd tv and there's a thick white vertical line down the center of the tv. I don't know what to do about it.
If the unit is under warranty, return it to the manufacturer for a replacement or a refund.
What you need t check is that the voltages from the printed circuit boards to the LCD panel are giving the correct voltages, also check the logic printed circuit board for shorted components or incorrect voltage values, if after checking the voltages frim each printed circuit board, everything is testing ok, the problem may be that you need a replacement LCD panel. But make sure to throughly check the main printed circuit board for any faulty solder jouints , or dry joints, as well as any blown or shorted components. I hope this helps. Good luck.
Jun 20, 2010 | Sanyo DP26648-R 26 in. LCD TV
Liquide coms from RGB back projection tv.
The CRT will need to have new Coolant and new seals installed, and any circuit boards that were dripped on will need a very detailed cleaning to remove any residule as it can ruin the circuit board traces and solder connections
Jun 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
The HDMI connector broke loose from its mounting inside the tv.
hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
Feb 08, 2009 | Samsung LNR269D 26 in. LCD Television
Circuit Board
if you didn't damage it to bad you could take a wire and use it as a jumper to cross over the traces you drill thru.
Dec 06, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
No signal on TV, black screen
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Dec 15, 2017 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
