Question about Mitsubishi VS-60705 60" Rear Projection Television
How to disassemble mitsubishi vs60705 black box and reassemble. Service manual does not describe this.
    Scholar:
  • 55 Answers
Do not take black box apart the front screen will lift up but do this gently and if you take the frame off the screen make sure you do not allow to bend it is plexie GLASS and will BRAKE if you need to support it put a chair in front with a pillow for the screen to sit on....be slow take your time remember to blow out dust before cleaning miorror and projectors lens then blow out just before putting front screen back, then wipe the lens again last before putting dust cover back on the lower rear.
Posted on Dec 16, 2009
  • Doug Warne Dec 17, 2009
    1st TV is cool,
    2nd Remove the Front lower speaker cover by pulling left and right ends toward the front there are upper and lower plastic hold pegs on each side
    3rd remove the panel located between speakers
    4th remove All screws out of plastic control cover located just below channel,volume ect...
    5th remove anything on top of the VS-60705 DVD,VCR,Cable boxes est....
    6th gently lift each top corner of Plastic Screen Frame.
    take note: there are 2 pegs at the middle of each side of the screen frame and 3 hook mounts at the top of Screen Frame. The top Hook Mounts flex wraps around top Screen cover, where the side hooks just rest on the TV housing.
    7th Lift frame up and the Screen Frame Releases and place on Ground in front of TV.
    Remember The Screen is PLEXI GLASS and if you remove the Frame and allow Screen to bend it will BRAKE and you are Totally Screwed....!!!! So just be nice and do not Bend, Walk On, Drop Tools or Hammers onto...!!!
    8th Remove Rear Dust Access Cover Screws Remove Cover
    9th Get Wet/Dry Vac and Use A Clean Paint Brush and began to Brush Circut Boards while Blowing The Dust Out and Off of TV.
    Clean Inside Projector Lens With Glass Clean, I spray onto Soft Cloth and then Clean inside of Projection Miorror I use Paper towls and then inside of Screen Sitting on Floor
    10th I put the Front Screen Back on ready to mount but i take and blow any dust off with vac and then lower Fame back onto mounts making sure the 3 top flex mounts lock and frame is flush with TV case,Replace screws next, then middle panel back on then speaker covers pushes back into Mount Plugs.
    11th I then got to rear and wipe off the Projector Lens one last time and put the rear dust cover back on....Cresto" wow like brand new"....make sure you brush dust off because moisture loves dust and then makes a unwanted Ground and POW something just Smoked...!!!! hope this helps anyone out MERRY CHRISTMAS" ....Our Savior IS BORN Happy Birthday JESUS"
I have a mitsubishi tv no,vs60705come on in turn back off
Its a very old set---The first thing I would do if working on it is unplug and open and look for any signs of leaking Glycol that it uses to cool the picture tubes inside. If seen do not touch it as it is toxic.
Apr 27, 2012 | Mitsubishi Televison & Video
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
Hi my name is Mike, I need an owner's manuel for for a BIG SCREEN model vs60705 made 11/99 rlms thank you.
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps
Apr 04, 2011 | Mitsubishi Televison & Video
HOW TO REASSEMBLING MY LAPTOP FOR DELL D410?
Here's a link to the service manual for the Dell Latitude D410:
http://support.dell.com/support/edocs/systems/latd410/en/sm/index.htm
This service manual describes in step-by-step how to disassemble/re-assemble this laptop model.
Jun 12, 2010 | Dell Latitude D410 Notebook
Removing exhaust manifold
http://tearstone.com/eclipsefsm/15.PDF
(Click this link)
This is the section of the factory service manual that deals with the disassembly and reassembly of the intake plenum and the exhaust manifold. The posted numbers is the sequence of the disassembly and reverse when you are ready to put it back together. Torque values are also displayed. The exhaust manifold teardown for the 3.0L engine begins on PG. 17
feel free to contact me if you require more help
Mar 18, 2010 | 2001 Mitsubishi Eclipse
Need a owners manual?
Contact your local mopar/dodge dealer or try to google online.
Mar 31, 2009 | 1992 Eagle Talon
Bad capacitors
go to the link below, they have the factory manual with fetailed photos of the disassembly and reassembly of your unit.
http://servicemanuals.vstore.ca/
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WT-46809
I advise you to first get a service manual as some adjustment will be necessary, it will also show you how to test it and how to disassemble and reassemble it. You can get the parts from any electronics distributor or online. Search for electronics distributor on google. for starters check out jayso electronics, they might have it in stock, you will need the part number and location number,
May 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi ws 55807 have the blinking lights problem and not powering on
Yes on some sets are a bit differant depending on the model number there is still a DM board. The disassembly is a bit different and the service manual will describe how to take apart the TV set to get to the DM board. The repair is the same for the DM board. I am sorry but I do not have the the service manual but one can be downloaded here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=WS55807 Good Luck
Jun 20, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
567 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
