Question about LG LRBN20512 Top Freezer Refrigerator
LG refrigerator bottom freeze LRBN20512
Vegetables in lower bin freeze. The seal leaks between the bottom freezer and the conduit that carries cold air supposedly into the top of the refrigerator compartment, allowing cold air from the freezer to flow directly onto the vegetable bins. Repeated service calls no help. Some apply caulk that soon gets blown through. There ought to be a better seal. Maybe LG has one, although, given their crummy Web site and general unresponsiveness, it seems impossible to get any help from them.
  • Paul Dawson Jan 28, 2007
    I don't understand. I posted:
    That's a model number they still use.
    Serial No. 412MRTT00801
    Does that help?
Why wont my freezer and refrigerator get cold? What could be causing this problem?
If all is running, the compressor isn't pumping, or there is no gas in the system. Is there any heat from the compressor area?
Apr 26, 2014 | LG Bottom Freezer Refrigerator w/ Swing...
Why wont my refrigerator & freezer get cold?
If all is running, the compressor is not pumping properly, or the refrigerant is low. or blocked.
Vegetables freezing in lower trays
lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
Dec 30, 2012 | LG LRTP1231W Top Freezer Refrigerator
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Puddle underneath fridge on occasion--tube coming down seems ok
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Feb 02, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Freeezes vegetables milk etc. even with refrig turned up.  Tried turning up freezer by 2 pts. ..Then tried turning up refrigerator to 44..Still no luck.No one seem to repair Lg Refigerator.s  in...
Have you made sure that the door to the ice maker area is closed and tighly latched? If the door is not pushed closed so that you hear the latch snap shut, colder air from the ice room will leak past the gasket and result in freezing in the bins and / or on the bottom refrig shelf. Another possibly might be air leakage at the very back bottom of the refrigerator section, where the air tower comes out from the freezer section.
Oct 07, 2009 | LG LFX25960ST Stainless Steel French Door...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
LG LRBN20512 Top Freezer Refrigerator Logo
196 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
