Kenmore HE 2 Plus washer doesn't high-speed spin
My Kenmore HE 2 Plus washer doesn't generate any error codes, but when it should be performing the very last high-speed spin it does not; the pump runs for a couple of minutes, but no spin; this results in soaking wet clothes at the end of the cycle. All other spin events during the cycle are normal. Again, there are no error codes, in particular no imbalance. This problem now happens on 90% of all loads; 10% of the time it will spin the clothes quite dry.
Running the diagnostic self-test, the final high-speed spin happens just fine.
I've had two different Kenmore repairmen out to look at it. They just scratch their heads and admit they have no clue. The last one replaced the computer, but this didn't solve the problem.
  • shellfish902 Jan 19, 2009
    Mine is doing the same exact thing and i can't find my manual on it either, i don't know what to do.
  • Anonymous Mar 10, 2009
    we have the same problem. have you found anyone to help??
5 Suggested Answers
  • 641 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
Does the washer was loaded when you make the diagnnostic test ?
Posted on Jul 20, 2007
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
  • 13433 Answers
SOURCE: spin speed too slow
When the clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: My front loading Kenmore Elite HE3 washer leaves clothes soaking
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Front Loading h2 (110.46462501). Was not spinning out water or going into high speed spin. Replaced belt (was stretched) and will spin out light load but not heavy. Tried heavier load and during...
I need to know specifically which lights are on...And if this is an HE2, He2 plus, or HE2T,,,
The lights give the error code to be certain... Also tech sheet behind front bottom panel will help identify error code and how to diagnose exact problem.
Mar 20, 2010 | Kenmore 46462 Front Load Washer
Kenmore Series 80 washer NO High Speed Spin
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer doesn't spin at high speeds
it is more then like the gear in the final spin is going out i suggest calling some one who services kenmore products
here to help
Shaun
Nov 17, 2008 | Washing Machines
Kenmore HE 2 Plus
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Sep 27, 2008 | Washing Machines
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
