Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer
I changed the latch mechanism and the code f du code keeps flashing and the door wont unlock.is there a way to reset it?its brand new???
  • 240 Answers
Brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Posted on Dec 03, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Front Loading washer Kenmore Ht3
    Here are the steps to unlocking the door manually if clothes are still in the machine.
    1.Unplug machine
    2.remove bottom panel
    3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
    4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
    5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
    6. You may now open the door.
    This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
    Nov 15, 2008 | Kenmore 46462 Front Load Washer
    Kenmore front load washer door
    A lot of these errors on these front loaders can be resolved by simply unplugging the washer for 30 minutes to reset the computer. You may also attempt to manipulate the door latch by using the manual release lever to see if you can get the latching mechanism to stay open. The following link explains how to do this:
    http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
    This is normally used when the door is latched with the door shut, but it still may apply in your case. If you attempt any of these preliminary checks and the latch still does not work properly, I would recommend replacing it. The next link explains how:
    http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
    Hopefully you will not require any replacement parts. But, if you do, a replacement latch can be found at searspartsdirect.com or repairclinic.com. Just type in your complete model number to perform a search for parts. I hope you find this information helpful. Let me know if you require additional assistance.
    Sep 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore HE3 front loading automatic washer
    The problem you are experiencing is a defective door latch. This is an easy repair you can perform yourself if you wish to save a service call. The following link explains the error, how to unlock to door if jammed, and provides the steps necessary to replace:
    Searpartsdirect.com carries your door latch. Just type in your model number and look under the various links on the next page. If you run into difficulty finding the part, let me know. I hope this helps you.
    PS If your washer is under a service plan or warranty do not attempt this repair or it will void any service agreement you have.
    Aug 07, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    F and then dU flashes
    The du error code relates to door/lid that cannot unlock. Check that there is no excessive weight on the lid. In case this is not the issue, you should check the lid switch unit. Good luck !
    Dec 02, 2006 | Kenmore 42822 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    493 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
