Question about Sony KP-57WS500 57" Rear Projection Television
SONY KP-57 WS500 Works for about 30-40 min
MY Sony Projection TV works for about 30-40 minutes if turned on after an Hour or 2 later. It works fine during this time then the picture starts fading then a flash of green comes on then whole screen goes green the picture returns to original good quality this goes goes on for 5 more minute (Good Picture) then once again picture starts fading green flash and screen goes green, Picture returns. this cycle happens 3-4 times then finally the TV goes to standby with stand by light flashing 8 times a pause and flashing again 8 times and TV put off. If I start that same moment the Picture comes back and tv works for about 5-7 min and again same routine finally goes to standby. The Picture the color composition and sound are perfect when the TV is started and till it gets in to that routine (heats up I think). The On screen error code I have checked it showed me #8 as reported error code. I resetted it to factory default and waited to happen again it once again came with #8 as error code whic matched with blinking code. Is it the D-board at fault with IC T8005 need to be changed or something else ? I have taken out D Board and checked all components for dry solder or burnout symptoms None seem to be loose or burnt out but could not check individual components and the leakyness of capacitors or resistors! visually they looked fine to me !!! ( I am sure One can not tell visually about the leakyness of circuit and circuit board components and so about the ICs)
Any solutions or any reasonable repair person !
Your Inputs are highly appreciated
Thanks a lot
parimal
parimalsheth@ gmail.com
  • parimalsheth Dec 04, 2008
    Thanks for your comment...Is there any way I can get this board checked up and fixed ?
    may be by someone more qualified than me to do it?
    Parimal
  • parimalsheth Dec 21, 2008
  • Sony Master
  • 5,138 Answers
How many people does it take to tell you GREEN TUBE is Shorting out.?green tube/ green tube/ green tube/I have a good new tube for sale 150.00 plus shipping.
Posted on Dec 21, 2008
    Scholar:
  • 113 Answers
Hello! there's a lot of factors why that error occurs, and sometimes just seeing it visually can't solve the problem but testing it one by one is all that counts. Let's trace the problem... 1. Focus on the power supply, from AC input to its power supply logic board, there are only three components has the source and converts power to supply to display board, its the transistor, capacitors, resistors, and diodes. If you have the digital tester, just test them all. If things okay then... 2. Focus on the display logic board. a bit difficult but its the only solution you have to figure out the main problem. Same process check the common components. If you find the messy component then it needs a replacement, all you have to is to take off that component and got electronic let them see the component and it has a replacement, then... 3. If still gone bad, it needs a repairman, look for a service center near you and ask for assistance. Good Luck!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear to be as welcomejee has described. Alternately, another possibility is the drive transistor/IC of the small PCB (printed circuit board) at the very rear end of the green CRT (cathode ray tube). This is rather difficult to access and test. However I would suggest running a simple test with the rear cover open. Power on the TV and with an insulated rod (I use a portion of an old fishing rod) poke around and on the board itself gently. If it is a cold solder, corroded terminals, loose connection, the problem would be determined.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 10,594 Answers
As you said TV gets green picture and then goes to standby with 8 times flash error code.
This is problem with Green Picture Tube (green gun) and you need to replace it.
This is not D board problem nor T8005 is defective.
You can notice few white retrace lines across the screen when it becomes green and then standby.
This is Green Picture Tube problem and green tube needs to be replaced.
Posted on Dec 11, 2008
    Master:
  • 479 Answers
Http://dukeelectronic.com/ u can check out this link and send the unit to get it repaired here.or call them at your place. and this site  repair center for any type of tv problem in sony televisions.
http://www.ercservice.com/Sony-repair/sony-tv-repair.html
thanks.
  • Sony Master
  • 586 Answers
    According to the symptom and LED 8 times blinking,This fault is related to the given below parts.Please check these IC's.And replace the who's being malfunctioning.
IC2601, 2602, 2603 are broken.
PS6103, 6104 are broken
Surely this will solve your problem.
Thanks for using fixya.
Posted on Dec 04, 2008
  • Sony Master
  • 4,806 Answers
A good way to check them if there are no visible signs of failure is to check the continuity of the resistors and capacitors with an electrical tester. It sounds very much to me that you know what you are doing and you seem to know what the problem is, however i will check into it for you.
kind regards
Posted on Dec 03, 2008
  • Lee Hodgson
    Lee Hodgson Dec 03, 2008
    It could also be the convergence, adjust the convergence again using FLASH FOCUS.
    It is recommended to perform FLASH FOCUS about 30 minutes after the
    projection TV is first turned on.
    Receive a TV or cable TV program.
    Press FLASH FOCUS.
    The cross pattern shown below appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes
    white and you are returned to the program you were watching.
    You cannot perform any other functions until FLASH FOCUS has
    completed its cycle.
    If you perform any other operation while FLASH FOCUS is in progress,
    FLASH FOCUS operation is canceled.
    Unshielded speakers or other metallic objects can cause picture
    distortion if placed close to the projection TV.
    kind regards
  • 4,472 Answers
This means a "high voltage" error. The D board would need replacement/service as it is your fly back transformer that is bad. If you need further assistance or help locating a service center let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Dec 03, 2008
    The error your stating has nothing to do with a convergence ic it sounds like someone doesn't know what they are talking about please do not take that advice as this is why sony uses the error code system to make trouble shooting much easier.
    Sergeant:
  • 217 Answers
Its the problem of convergence ic on the main board of the tv and it needs to be replaCED.also any of the capacitor is getting heated up and creating this on.off problem.that has to be checked on the main board and replaced.
I have a sony KP-51HW40 and when i turn it on about 5 minutes later it shuts it off.
If the TV works fine during the 5 minutes its on then your power supply in the tv is heating up and shutting off. If you have some mechanical knowledge you can buy another power supply from Ebay for around 35.00 and replace it. will require some soldering
Jan 23, 2011 | Sony KP-51HW40 51" Rear Projection...
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Our Sony KV36FV16 works perfectly for 5 min. then powers off.
After speaking to a local TV repairman, the concern of labor and unavailability of parts, led us to purchase a new TV!
Dec 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57
Sounds like a convergance amp problem or possibly the S.D.K.'s are going out
Apr 20, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony rear projection tv
Bad green crt, this set has a problem with bad crt's
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Green screen...
Probable bad green CRT..........usually about 600.00....T.
Aug 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
