Question about Proscan PS52800 52" Rear Projection Television
Auto Convergence failed becuase PS52800 failed to detect one of my Sensors?
Hello~ That is the message I get when I try to execute auto-convergence. It fails to detect one of my sensors whatever that means. It also recommends making the room darker and trying again. That's not it. I don't notice a color problem though, if that's what convergence is. The model is RCA MM52100 from 2001. It has a serious overscan problem (top and bottom), the picture has always been too dark, and it's out of focus at the perimeter. Otherwise it's wonderful. Can someone point me in the right direction? The set is watchable, so I don't think it's too major. I'd like to get a picture that someone might buy so I don't have to pay to have it hauled away. Anybody? Thanks.
    President:
  • 1,284 Answers
The overscan would certainly cause auto convergence failures since the beam the CRT's shoot out are on the corners and upper center and lower center. Being too dark can also cause issues since one of the CRT beams might not be bright enough for the sensors to register. I would first have someone adjust the vertical size if the top and bottom of the frame are somewhat cutoff.
Posted on Feb 19, 2007
I have a LG RT-39NZ40RB and i pressed the Auto Convergence button. Every since there has been a red shadowing around the picture, how can i turn off auto convergence or fix this problem
I suggest waiting an hour then do the auto convergence agian, if this fails then it means there is an issue on the convergence board.
Jan 05, 2010 | LG Televison & Video
I can't adjust my convergence LG RU56nz23
Hey...
If you have already tried auto convergence under special in the tv menu and still cant get it i had your problem.
One of your convergence sensors is dead and you have to replace it if you have no experience with this kind of problems call lg and tell them your model and that one of your convergence sensors is out ask them for a tecnician they will charge around 30$ for the tecnical visit and some extra for the repair
P.S your model has to have this line in it (-) (ru-56nz23)
Jul 06, 2009 | LG Televison & Video
Tiny Mirrors Around the Screen of the Hitachi 51" Rear Projection
OK.. These are photo-sensors for auto-convergence function and without these sensors, auto-convergence function will not work properly.
Jan 02, 2009 | Televison & Video
Screen is pinching
you may still have a fl231 fuse type problem. I would first suggest resoldering the flyback connections. dince this happen ever so often it possible a connection problem. If i had it in the shop i woould chek the flat ribbon connectors also. convergence is controled by three board, convergence power, convergence amp and small signal board. since it pinches this is indication of interuption of convergence power supply. the auto convergence not working. is a symptom of small signal board issues. the small signal board requires specal interface equipment to download data off to place on new board. or the sensors arond the screen has failed.
Dec 10, 2008 | RCA R56WH76 Projection Television
Convergence prob for d52w26 rear projection tv 52"
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Convergence 3D
You have to try auto convergance from the menu.
There ust be convergance adjustment on menu.You will find cross at center of the screen.green cross is the refrance ,you have to overlap red and blue to form white cross.
once you have formed white cross than the picture will be perfect.
Jan 09, 2008 | Zenith R56W36 56" Rear Projection...
Multiple images on right side of screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergance amp ic bad
Dec 23, 2007 | Toshiba 53H71 53 in. Rear Projection...
Convergence
Sensor not reading problem is due there is some obstruct between sensor and projected light beam. Check any disturbance are there and clean the sensors. Cleaning work is done by the technical persons only since it is sensitive area. Try another method also by changing the TV aspect ratio is 16:9 and then select auto convergence method. This is the one chance is there before you call the technical person
Sep 05, 2007 | RCA P61310 TV
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Proscan PS52800 52" Rear Projection Television Logo
91 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
