Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Soap dispenser door doesn't open
Replaced the wax motor, but the door still doesn't open. All other parts in the dispenser are ok
  • papa703 Dec 05, 2008
    How do I find out??
    Sergeant:
    Champion:
  • 338 Answers
Make sure you have 120 going to the ax motor.. if you dont then replace the control.
Posted on Dec 01, 2008
  • Robert Artiaco Dec 07, 2008
    it takes a little bit of time but hoow your meter up to the wax motor and start the dishwasher and just wait you should see the voltages change.
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
The soap door does not open during the wash cycle
Hi
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dispenser door will not open during operation
Hi
Hope this helps... Please revert for any further assistance.
Daniel
Aug 26, 2010 | KitchenAid Dishwashers
Does not release soap from despencer
Hi
Daniel
Aug 21, 2010 | Dishwashers
Water is coming up through the kitchen sink when dishwasher is running and teh soap depenser will not release the soap.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these. Please do rate this solution and revert for further assistance.
Daniel
Aug 14, 2010 | Maytag Dishwashers
Soap dispenser won't open during operation
Hi
Daniel
Aug 02, 2010 | Maytag Dishwashers
The soap dispenser fails to open at times
Hi
Bosch dishwashers (not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced.
Older Bosch dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Thanks
Rylee
Oct 12, 2009 | Bosch Dishwashers
Soap dispensor not opeaning, and soap tabs are not dissolving
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool & Frigidaire dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Thanks
Rylee
Aug 04, 2009 | Frigidaire Dishwashers
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
