Question about Nintendo DS Lite Console
Turns on and lights up but no images on top screen
My sons DS will turn on and both screens light up but when a game is selected nothing is shown on the top screen. It just remains with the grey/ white plain screen. The game runs as normal on the bottom screen.
  • landon Nov 02, 2012
    me to
  • 903 Answers
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from this appears to be a common problem I hope this helps
Posted on Dec 01, 2008
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Green light, black screens, no sound, needs new battery???
The alarm is just a coincidence i suspect, green light comes on and stays on probably not the battery at fault. It would be red.
If the green light goes out and screens just flash one of your screens are at fault or a loose ribbon connection.
Jul 01, 2009 | Nintendo DS Lite Console
My son dropped his ds lite. When plugged in the light turns green. When you try to turn it on the top screen flashes then goes off
The DS lite is easily broken when it is dropped keep trying it or ask for a repair where u bought the ds
My son's ds won't turn on
Was the DS dropped? Sounds like the top screen ribbon has become disconnected from the motherboard, or is broke. You may have to replace the top lcd screen.
Apr 01, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Screens wont come on
Are the connection wires still intact between the screens or are you inable to see?
Dec 01, 2008 | Nintendo DS Lite Console
If I understand it correctly, the screens are still dark.
Small question....was it dropped on the floor?
Jul 23, 2008 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
Is my Nintendo DS Dead?
You are going to have to send it so that they can reset your system. Also, it could be that it is working but there is a short to your LCD screen. look around at some companies that fix gameing equipment. I went to and they fixed my sons DS. he had dropped it and the top screen would not come out. they had to change out the LCD screen.
Apr 24, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
653 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
