Question about Kenmore 82722 Electric Portable Dryer
Kenmore Portable dryer, shocking
I have a Kenmore portable Heavy Duty 110v 3 prong Dryer. when we get clothes out of it we get a slight little shock from the rim of the dryer, feels like a constant static electricity shock as if some one was rubbing feet on carpet. then recently the cord has been heating up after only a load. I have taken apart and blown all the dust out as well as checked all the wiring. I was wondering what it sounds like could be the problem.
  • awjandy Dec 01, 2008
    i will check the plug Box, please define the reversed polarity issue,
  • 88 Answers
To me it sounds like you could have the polarity reversed on the wiring. Also is the outlet that it is plugged in to grounded that alone will cause a shock to be given off, Have goods holiday, biigg53566+
Posted on Dec 01, 2008
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
Went from a 4 prong to a 3 and get shocked sometimes.
You need a meter. Unplug the dryer and check for continuity between either of the 2 hot legs and the frame.
Sep 04, 2012 | Kenmore 62602 Electric Dryer
Hi, we have a kenmore heavy duty 70 series electric dryer, it will not start, there is 110v to each leg of the plug, and the door light comes on. What would I check next
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Kenmore Dryers
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Broken Spring/Shock for my GLEQ642AS0 Fridigaire Dryer
there are no "suspension shocks/springs" on a dryer, those are usually on your washer. here is hte par number for he washer spring 134144700(which is about 8 inches long and 3/4" in diameter made of heavy gauge steel) youll need (2) and heres the suspension shock absorber number 134564200 its a set of 2, there shold only be 2 on your machine.
Dec 11, 2008 | Frigidaire Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Kenmore 82722 Electric Portable Dryer Logo
263 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
