Question about Samsung TXH1970 TV
Samsung txh1970 tv screen has green tint
No picture adjustments work to remove the green tint.
also inside cabinet color adjustments (that i can find)
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Posted on Jan 26, 2009
  • Anonymous Jan 26, 2009
    Ok - here's another possibility. This is posted on Samsung's website under support FAQ. Worth taking a look:
    http://www.samsung.com/us/support/faqs/s...
    How Can I Degauss My TV?
    Samsung CRT TVs Degauss automatically when you turn them on. Consequently,
    they do not have manual Degaussing controls.
    However, if the picture
    on your TV is ** green ** , purple, or blue on both sides or distorted at the edges
    or corners, you're
    probably seeing the effects of magnetic interference from a nearby electronic
    or magnetic device such as a pair of speakers, a clock radio, or a stereo
    receiver. To resolve the problem, move all electronic or magnetic devices away
    from the TV by at least three feet.
    If this doesn't resolve your problem, try turning
    the TV off and on once.
    Note: Turning your TV on and off quickly several times in a row
    can damage the Degaussing circuitry.
    If turning the TV off and on once doesn't work, you may need
    to run the automatic Degaussing several times. To do this without damaging
    the Degaussing circuits:
    1. Turn the TV off.
    2. Let it sit for fifteen minutes.
    3. Turn it back on.
    4. Wait a minute or so, and then turn the TV
      off.
    5. Repeat the process several times over the
      course of an hour or two.
    If the suggestions above do not work, and you continue to have trouble with your picture that you think may be caused
    excess magnetism, call Samsung Customer Care at 1-800-726-7864 for additional
    assistance. Have the model number and serial number of your TV on hand when
    you call.
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Red tinted picture
HI,
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
Apr 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Samsung ln-s4092d no red tint
There are a few things that can cause this. Your t-con board, the signal board or the screen itself. The most likelly and cheapest would be the t-con board. This is the board that transfers your picture from the signal board to your screen. You would have to open up your tv and get the part number from the board itself.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Samsung LN-S4092D 40 in. LCD HDTV
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Can damp conditions cause TV to go out
If you have too much dampness, and or mold inside the set on the circuit boards, most likely there is damage.
The cost of servicing may be too expensive in consideration of the value of the set.
Jerry G.
Jan 19, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Green tint in the color on my big screen tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 12, 2017 | Samsung Televison & Video
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Samsung TXH1970 TV Logo
1,007 people viewed this question
Henry  Thomas
Henry Thomas
