Question about Linksys Computers & Internet
VOIP vpn isssue
I have a pbx with voip at the host that has static Ip addresses on the Host end, I have no known static IP vpn tunnels on the far remote end only a 192.x.x.x the PBX manufacturer ( NEC Aspire) demands a VPN tunnel any ideas
We are using a 8000 series router on the host end
    Sergeant:
  • 217 Answers
Remove the router and reconnect.and also reinsert your ip adress again .
Posted on Dec 01, 2008
Iam having different ips from wan is this mean someone is accessing my network?
You just have Dynamic ip, nothing to worry about.
"Static IP addressing is for one customer on one IP address and Dynamic IP addressing assigns a different IP address each time the ISP customer logs on to their computer, but this is dependent upon the Internet Service Provider (ISP) because some ISP's only change the IP address as they deem it necessary.
If you have Dynamic IP Addressing through your Website Host it means that you are sharing an IP Address with several other customers.
If you are a beginner on the internet, an avid internet user, are entertaining the thought of starting your own website business, are a gamer, use VOIP or VPN there are several things you should know about IP Addressing."
Read more
Mar 21, 2011 | D-Link DIR-600 Router
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
May 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Voip tunnel configuration was not received on address
Establishing a VoIP tunnel requires that you have either an accessible IP on the remote host with which to do IP-IP calls or that you have a VoIP server with which to route the calls between IP digital and analog lines.
Usually this error indicates that in the configuration somewhere you have entered a destination IP that does not recognize either of these as being available. So the first thing I would check is your Firewall settings, then your network connectivity, and then troubleshoot your IP destination.
See if you can ping your VoIP destination from a command line and if connectivity seems good, make sure that everything needed to initiate the connection is running on both ends.
Sep 29, 2009 | HP Pavilion dv2000t Notebook
We need PPTP, L2TP Solution for VoIP
You can establish small tunnel with low cost firewall from linksys and do the VoIP with ADSL, lease line etc. You can use Linksys SPA 9000 IP PBX and SPA9XX phones. I have done a project and still expanding - UAE - OMAN
Sep 24, 2009 | Computers & Internet
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Jun 23, 2009 | D-Link Express EtherNetwork DI-LB604...
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Setting up voip on nec ipk2 phone systems?
The easiest way is to set up a different extn number range for the sites, then in the system settings in the number scheme you programme the system with the ip address of the distant end against the extensions. Obviously you need a VPN between sites but it works really well as we have a number of installations like this
regards
Feb 06, 2008 | Computers & Internet
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Communication problems over IP phone
I have found many possible causes. Firmware Levels Outdated firmware in routers, VOIP phones, Firewalls, etc. can cause one-way audio. Ensure you have the latest updates for all the devices in the call path. Configuration Particularly if NAT is involved in the call path, configuration of the various devices may be a problem. Check to see if all devices are configured appropiately for your envioronment. Has anything changed, carriers harware, quos settings on router ? packet loss to these locations should be tested @ time it happens most, don't use it as gospel retur, ttl and re-xmits' do same.. Bob Finding the Cause The basic troubleshooting technique is to use a tool like Ethereal to capture SIP and RTP packets at each point in the call path where packets could be lost. Interperting the resulting captured packets requires some familarity with how networking and VOIP work. For example if the call path is: VOIP phone/device ---- firewall ---- sip proxy ---- firewall ---- asterisk Troubleshooting Steps Start capturing at point Make a VOIP call that will have one-way audio Analyze capture If problem found, fix and retest Otherwise move capture point to the next point (a, b, c, d, etc) and start over If the problem is intermittent, then a long term simultanous capture at multiple points can be used to attempt to capture a comple call with the problem. Most capture tools will let you capture only traffic from selected devices, so the volume of captured information can be kept to a reasonable size. If a back-to-back SIP user agent (for example a Session Border Controller ) is part of of the call path, then it may be necessary to capture all VOIP traffic at some points to ensure catching the wanted call since the IP addresses can change when traversing this device. Resources How To Debug and Troubleshoot VOIP
Nov 14, 2006 | Nortel I2002 IP Phone w/Text Keycaps, No...
Computers & Internet Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
