Question about Mitsubishi WS-55513 55" Rear Projection HDTV
The picture at startup and for approx. 2hours is squeezed in at
Top and bottom. of course not properly converged. after long warmup the picture is just fine. don't have repairman close by.
  • 4,234 Answers
Since the set seems to "correct" itself, it suggests that there may be some poor solder connections that are causing the initial problem. If you can solder, try resoldering the pins of the convergence ICs. If that fails to resolve the problem, let me know and we'll start looking at other component failures.
Dan
Posted on Dec 01, 2008
Top half of picture is good but the bottom half has green and red shadows
needs new convergence chips, has 2, stk392-110, they need to be soldered in. probably need a tv repairman.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Picture curves in @ top and bottom and color convergence is off. was fine yesterday.
There are bad solder connections on the flyback transformer and there is a small fuse open. Pretty hard to do yourself but a professional can do this easily.
Apr 15, 2009 | RCA HD56W66 56" HDTV
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
Left top and right top of screen curled, bottom middle of screen has a hump to it
Yes you need to repair the convergence circuit. If you know how to solder and use a meter this can be fixed easily by yourself. If you call a repairman to do it, it will run you $300-$500 depending on your area. Let me know if you can use a meter and solder and we can move forward with repairing you set.
Tim nolan
Sep 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshba CF27E50/CF30E50/CF32E50
The convergence IC needed are STK 392-110 two of them and possibly a resistor or two If you don't know how to unsolder and solder I would suggest an honest repairman. most Parts distributors won't sell unless you have a business but you could try anyway. A volt-ohm meter is required "IF" a resistor needs to be checked or is burned. Convergence IC's are a common problem with all projection tv's. It may last another 5 years especially if you don't buy the generic ic's
Dec 30, 2007 | Toshiba 55H70 55" Rear Projection...
Convergence out of addjustment
You need to get a service tech for that problem,it might need new amps for the convergence and then adjustments that only can be done from the service menu.
Aug 30, 2006 | Mitsubishi WS-65908 TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
