Question about HP Pavilion a1410y (RB042AV) PC Desktop
Pavilion a1410y won't read second memory module
I installed a second 1GB memory module. The computer only reads the first slot, regardless of which 1 GB memory module is in the second slot. The two memory modules are from the Kingston and are the same model but purchased at different times. HP troubleshooting support says the problem is software and wants to charge me for support time. I've looked at the HP website for drivers but everything seems current.
The computer also won't create recovery discs. It always encounters a problem when starting to write to blank discs. Has anyone heard of this problem with this computer?
I don't think that the problems are related but wanted to mention all the problems witht he computer.
Any suggestions? Thanks.
MESQUER
  • mesquer Dec 03, 2008
    I have already done this (looked at the setup screen and checked). The computer indicates that memory is not installed in the second slot even though the memory is physically installed. Do you think this is a motherboard problem?
  • Anonymous Feb 09, 2009
    I have the same problem. In inability to support two HP recommended memory modules that are installed in the two memory slots. A1410y recognizes only one of the two modules. Pursued this problem when the computer was relatively new in 2007 however HP support provided conflicting recommendations, then fell back on the "reload the XP solution" which has nothing to do with the BIOS problem and easily sends complainers away. I have been living with a single 1GB memory stick with XP since. It is starting to get tight with the newer applications which are not built with small memory model in mind.
    Based upon the number of similar questions and complaints found on the net you can feel comfortable in that you are not alone with the memory problem.
    Recent contact with HP support, where I was looking specifically for a BIOS upgrade, revealed that HP does not have a BIOS upgrade for the a1410y, They would not endorse any upgrade from the mother board manufacturer. They also suggested that the mother board is bad...something that was not suggested back when the computer was under warranty.
    If you still have the original recovery partition on your harddisk, you can easily effect recovery of the operating system. Be prepared to lose your applications and possibly your data though. You do not need to use the 13 or 15 horrible recovery disks.
    Keep us informed of your luck finding a BIOS upgrade.
    Tom
  • 59 Answers
Try checking your bios and see if it is seeing it. goto to this site on how to check your bios: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&dlc=fi&cc=fi&lang=fi&product=3254035
Posted on Dec 01, 2008
What is the maximum memory for this hp a1410y computer?
Max 2 x 1 GB DDR2 533 modules = 2GB MAX. memory possible.
Can use 1GB DDR2 800 RAM.
Jun 12, 2014 | HP Pavilion a620n (PC028A) PC Desktop
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Installed upgraded RAM in my HP Pavilion a1030n. Now computer will not power on even with the old memory put back in. what's wrong? Everything was fine until I unplugged the computer. I took off the...
YES. The slots are for different kinds of memory. ONLY use the 2 new cards and insert them into the SAME colour slots. You should NOT mix memory types. Forget the old modules.
Feb 14, 2011 | HP Pavilion a1030n (PS585AA) PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
New 1gb RAM, sys. only reading 478mb.
Although you have 1 Gb of RAM installed, I'm guessing you have two 512 Mb of RAM installed, it appears that only one RAM module is working.
Go into the BIOS and check if the BIOS sees 1Gb of RAM.
If it sees only 512Mb then swap the RAM modules around in the memory slots and check the BIOS again. If this doesn't work just install a single memory module at a time to determine which is the faulty memory module.
Jul 30, 2009 | Gateway Computers & Internet
Compatability of Memory Upgrade
DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
Regards,
Worldvet
Nov 20, 2008 | Computers & Internet
Memory installation
Most likely, it is a limitation of your motherboard. Not all motherboards or computers can physically read all types of memory or they may have memory limitations. For instance, I was working on an older Gateway this week. It had 2 memory slots but the maximum amount of memory the computer would recognize is 512 MB. Therefore, if I had put to 1 GB sticks in, provided the computer could use it, the maximum the computer would be able to see or use is 512 MB. In this instance, that is most likely the scenario. The best thing to do is to go to www.crucial.com and run the system scanner. It will tell you how many slots you have, what the maximum per slot capacity and the total capacity of your computer is.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Intel Motherboard
Toshiba satellite a100,wa-1 memory upgrade
Take out all the memory cards and wipe the gold part of the memory modules.
Then insert the two 512 modules & check the memory.
If it shows the correct readings, then the two modules are detected.
Then insert the 1 gb & other one 512 module.
Then use the other one gb with the same 512 & check if it shows the correct readings.
Then the two 2 gb modules are fine.
Now insert the two 1 gb modules & check now.
There are ECC type & non-ECC type memory modules are available, chck which one your computer supports & which type you have.
If it shows the correct readings, then the two modules are detected and fine.
Then you can also swap the slot and check if any memory module is not detectd correctly.
Some have four slots & i dont know how many slots your laptop have.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
HP Pavilion a1410y (RB042AV) PC Desktop Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
