Question about Ovens
Jenn-Air JMC7000 Microwave Stopped working
I have a Jenn-Air JMC7000ADW Microwave / Oven in wall combo that is 9 years old. My microwave stopped working last night. The oven still works. Do you think this is easily fixed? Thanks, I have a Jenn-Air Microwave/Oven combo, Model WM27160. I started a oven self cleaning cycle and the microwave stopped working. Everything on the microwave control console went blank. As in no power. Checked the circuit breaker and it was on and OK. Following the solution to a simular problem on another model Jenn-Air Micro/Oven combo I went looking for the reset button. Took the outside cover off. It took 6 screws. On the right side of the Microwave oven down on top of the Oven was a reset switch. The space as too tight for my hand so I used a yard stick to reach in and press down on the reset switch. I worked! The microwave oven came alive. I replaced the front panel cover and I was done. It seems that the heat from the self cleaning process caused the reset switch to trip open and cut power to the microwave oven.
Thanks for the solution for this problem. It worked great for me.
    Sergeant:
    Champion:
  • 338 Answers
Take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Posted on Dec 01, 2008
MY Jenn Air model WW2780W isn't coming on. When I click on the control panel it clicks then the display says 140 preheat on.. for about 30 seconds then it shuts off it has done it for awhile and it would...
I have the same double wall oven, and it will "turn on" and then shut off after about 30 seconds. The top oven stopped working 4 years, the bottom oven stopped working about 2 years ago. Both are doing the same thing. I'm interested in replacing the capacitors to see if that fixes the issue. There are 2 larger capacitors (1000uf 35v), and lots of smaller ones. Is it safe to assume it's the larger ones that need to be replaced? The only other 2 matching capacitors are very small (0.47uf 5v). I know this is an old thread but would appreciate any advice. Thanks!
Sep 27, 2013 | Jenn-Air Ovens
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
I HAVE A JENN AIR WALL OVEN AND WAS CLEANING AND MY JENN AIR MICROWAVE STOP WORKING DO YOU HAVE ANY IDEA'S
Check for a tripped breaker or blown fuse in your fuse box. Assuming they are separate units there is no common connection other then the power source.
Good Luck,
Gilshultz
Dec 03, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
538 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
