Question about Toshiba Tecra 8100 Pentium III, 850 MHz (  p000311140) Processor
I own a toshiba tecra 8100 that when i start it up it reads a message insert system disk in drive then it i insert xp operating system reinstallation xp professional service pack 2 it will go through half of installation and then it says unable to continue
  • 145 Answers
You will have to reinstall the system os
Posted on Dec 13, 2008
I have a Toshiba Tecra M7 where the hard drive went bad and need the reinstall disks for the Operating System to reinstall the OS(XP)
From there site:
http://support.microsoft.com/kb/310994
You can obtain Windows XP Setup boot disks from Microsoft, but only by download. We provide the Setup boot disks so that you can run the Setup program on computers that cannot use a bootable CD-ROM. If you can start your computer from a CD-ROM or from a network-based installation, we strongly recommend that you use those installation methods instead.
Future products will no longer support installation by using the Setup boot disks. Installation of future Microsoft operating systems will require the ability to start from the CD drive or by using PXE boot from the network. For more information about how to use PXE boot, visit the following Microsoft Web site:
http://technet.microsoft.com/en-us/library/cc782281.aspx (http://technet.microsoft.com/en-us/library/cc782281.aspx)
Aug 07, 2011 | Computers & Internet
On my Toshiba Tecra 8100, When I used the Windows 98 CD-Rom setup to get the laptop to work, by the time it was done, it said "invalid system disk. replace the disk & press any button to reset. What...
you need a new version of windows 98 as the computer has detected vast implants of previous versions you need to try to get a newer version of win 98
Sep 25, 2010 | Toshiba Tecra 8100 Notebook
I am having trouble reinstalling the operating system. THe message " remove disks or other media. Press any key to restart." There is nothing in the cd drive or floppy drive. I just want to do a fresh...
Insert the genuine Microsoft CD-ROM disk into the CD/DVD reader. Press any key to reboot the computer, reading from the disk, to start the reinstall.
Mar 26, 2010 | Compaq Presario 1200 Notebook
Toshiba 8000 system disc message
Hi Larry,
This happens when either the system disk is corrupt or faulty, or, when another disk with higher priority but no operating system is in the computer.
Typically removable disks like CD's, DVD's, Floppy disks, Memory Cards and USB flash drives can all take higher priority than your windows drive as any can be used to load up diagnostic software when it is damaged.
So, Remove all disks, USB devices(including printers), CD's or DVD's et al and try again. If this still happens with everything removed/disconnected, then your problem is with the Windows install or the harddrives physical components. If it works try reattaching/inserting the disks and devices one at a time then restarting and you will figure out which one is causing the problem.
If it didn't work you will need to get to a hardware shop and have them test the hard drive to see if it's faulty. If not contact Toshiba and order a set of recovery disks, when they arive insert disk one then turn the machine on and an onscreen wizard will walk you through re-installing. If they determine there's a hardware issue with the drive, either buy/warranty a new drive then order the disks from Toshiba and follow the above instructions.
Hope this helps FixYa,
Chris
Jul 15, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Tecra m2v-310
you might need to reinstall your windows XP or you could have a hard disk problem.
Write me what message you get for more help.
Mar 24, 2009 | Toshiba Tecra M2V-S310 Notebook
My Tecra 8100 will no longer boot
GO I2 THE BIOS SET UP DEFAULTS ,SAVE AND EXIT ,IT SHOUL DBOOT OFF THE CD DRIVE THEN H/DRIVE DEPENDS HOW YOUVE GOT IT CONFIGERD
Oct 28, 2008 | Toshiba Tecra 8100 Notebook
Help with a toshiba TECRA 8100
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
Sep 09, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Tecra 8100
I'm not clear on your description, so here goes:
If it showed the Toshiba start screen, then asked for a password, then your hard drive is password protected.
If it showed the Toshiba screen, then asked for password, and you entered it, and then it goes "insert disk", then your hard drive is passworded and wiped.
If the first thing it does is ask for a password, then the password is in the BIOS.
Aug 16, 2008 | Toshiba Tecra 8100 Notebook
Toshiba tecra 9000 wont start
Blue screens are generally operating system failure. You will need to reinstall your XP home. Format the drive NTFS, instead of FAT32. If you have any problems during or after the reload, then the hard drive is the failure and will need replaced.
Jul 01, 2008 | Toshiba Tecra S1 Notebook
Start Up Problem
Usually means that Operating Sytem needs to be reloaded or the hard drive is dead. Try to re-install Operating System first.
Hope this helps!
Mar 24, 2008 | Toshiba Tecra 510CDT (P000224080)...
Toshiba Tecra 8100 Pentium III, 850 MHz (  p000311140) Processor Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
