Cameras Logo
Posted on Dec 01, 2008
I have just bought a DVC 505 camcorder and am using it to take videos. Using the USB lead and videoworks 6 supplied with the camera I am trying to upload to computer. It uploads the audio but not the video. I have tried re-installing videoworks but it still is the same. I use windows XP. Have you any idea how to solve this? Yours, Ruth Jenni
5 Related Answers
Anonymous
  • Posted on Jan 19, 2008
SOURCE: Sony DCR-HC38E Exporting miniDV video to computer
I had a similar problem with my Sharp camorder.
The preview window on XP simply displays corrupted images.
At the end, I bought a different firewire card and it worked for me.
Good luck.
Alex
New Zealand
Anonymous
  • Posted on Nov 23, 2008
SOURCE: Sony cyber-shot DSC-N2 how to upload vidoe to pc?
I changed the resolution size under options before filming and uploaded the video onto my provided picture motion program given with purchase of camera. I then switched the file to my videos under my computer so I was able to upload them onto email, and internet.
Anonymous
  • 477 Answers
  • Posted on May 27, 2009
SOURCE: my camera wont upload videos, but it works fine with pictures.
Goto any radio shack and get a external memory card reader this will allow you to get your pictures if the camera or cable is defective.
Anonymous
  • 747 Answers
  • Posted on Jan 20, 2011
SOURCE: I have tried uploading photos
You didn't tell me what make of camera or a model but, to give you a general answer some cameras make pictures numbered to 100 then start a new folder at 10 So the "other" pictures are most likely in another folder that you will need to open the file and click to open.
Anonymous
  • 11967 Answers
  • Posted on May 16, 2011
SOURCE: when we connect our canon
Have you looked in "my computer" to see if the camera shows up as a "removable drive"?
3helpful
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
1helpful
DCR-HC38 computer not recognizing camera
Option 1:
If you want to use the USB cable to connect the Camcarder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
When I plug it into my computer with the sfotware installed the compuer does nto regonize that the camera USB is there??
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with VISTA, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
Good Luck!!!!!!!!!!!!!!!
2helpful
I have picture package 1.5 but when i want to convert the tape to cd, i can not select the source and target is there a patch for this ? This for DCR-HC32 E Also i have now bought a new laptop which has...
The supplied Picture Package software is not compatible with the Vista Operating System.
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
Option 2:
1helpful
Cant transfer videos to pc
Option 1:
Option 2:
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
2helpful
Computer can not capture from video camera
Applicable for Windows XP Operating System:
3helpful
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
2helpful
3answers
Win vista usb driver pv-gs50
i also need this driver gs50 i purchased it bestbuy in usa.
but there is not driver for vista.
2answers
Top Medion Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Medion Camera Expert? Answer questions, earn points and help others
