Question about Summagraphics SummaSketch III Graphic Tablet
Summa sketch mac osx compatibilty
I have recently found my dads old summa sketch III and i was wondering if it would work on an imac operating on osx.
Reset imac password
It depends which password yo want to reset. If it is the Mac OSX password then you will need to go through some linux commands. If it's efi i.e bios password than, you need a professional Apple service centre. You will need to boot your imac with osx disc and click on utilities and then reset password.
Tech from
MacBook repair,ipad repair Mississauga
http://www.computerstar.ca/mac-repair-apple-help-mississauga.html
Computer Repair Mac Laptop Repair PC Laptop Service Data Recovery iPad
Mar 12, 2014 | Apple 24" iMac Desktop
SummaSketch III drivers to work with Autocad 2004 and Windows 8
To use AutoCad with almost any digitizer, summasketch included it is recommended you download the driver from this site: http://www.vtablet.com only works with serial interface and costs +- $60 however they do allow u to use it for free for 30 days.
If u need a USB to serial that WORKS for your computer head to www.interworldna.com and search for the usbadpt adaptor
Hope this helps
Nov 02, 2012 | Summagraphics SummaSketch III Graphic...
I have a apple imac Mac OS X Version 10.5.8. I have a Summa Sign D610 cutter. I am looking for software to make it work.
  • Make sure all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords
Sep 17, 2011 | Computers & Internet
Safari doesn't work on this used Imac G4 I just bought, but Camino does work? How do I get Safari working on this old thing?
On the left Top of your monitor is a apple Logo.Tip on it and select "About that Mac" A Window pops up and you select "More Info" it shows you the OSX on it. OSX 10.3 or OSX 10.4 Google "Safari Browser for OSX 10.? " Download it and it will work. You may have the latest Version.
Oct 04, 2010 | Apple iMac G4 Desktop
I have imac. and i want to change his operating
Yes it is very easy to do as you are running a Mac with Intel Processor. You have Mac OSx Leopard with updates 1,2, & 3. To upgrade to Mac OSx Snow Leopard you must buy the upgrade. Go here: http://www.apple.com/macosx/ On the top right click (Buy Now) You will have to pay $29 which is a bargain. Once you get the upgrade on CD simply follow the directions for the simple upgrade. I did the same thing when Snow Leopard came out. It is well worth the $29.
May 29, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Mac osx can not be installed on this computer
What is the brand of your PC? Is it Imac also. Mac OSX can only be installed in apple computers.
Feb 25, 2010 | Apple Computers & Internet
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Cannot connect to Computer
Turn off computer. Turn ON computer and immediately hold down Apple+option+p+r. after 4 chimes let go. You are going to be using the Firewire cable. once the camera is on and plugged into computer go to : apple> about this mac> more info click on Firewire. on the right hand side you should see your camera. Now if you don't its either the Firewire port on camera or the cable it self. to further isolate. Get your older computer. leave off. plug the firewire cable into both computers. Now the older computer that is turned off. TURN ON and immediately hold down the " T " on keyboard. ON the polder mac, your screen with have like a "Y" icon.. its a Firewire icon. Now look on the other computers desktop, do you see a yellow or blue hard drive on desktop. IF you do.. ITS your camera because we just tested your cable and both ports and they are working. Now try the USB cable and see if its detected by computer by going back to Apple system profiler and see if the computer is detecting it
Mar 24, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Open Questions:
We have a digitizer we are trying to resurrect: SummaSketch III with 4-button Diamond Puck 12 x 12 MM compatible version 1.91 Win XP SP2 (version 5.01 build 2600) Tablet Works 7.46.0619 com1 All buttons work and are assignable The puck works in mouse mode. In WYPIWYG mode there seems to be some problem: In Tablet Works Control Panel, the digitizer area doesn't stick - the (almost) whole digitizer area is still used; a small selectable area cannot be defined. I use this in AutoCAD with the Wintab Comaptible Digitizer ADI 4.2 - by AutoDesk. AutoCAD will recognize the tablet and allow me to configure regions and a screen pointing area. Menu items on the tablet work and the screen area allows geometry selection. Here's the problem (you could feel it coming couldn't you): Counting up from the lower left corner of the tablet The tablet "sees" (steady indicator light) from about (4.75cm, 4.3cm) (my ref: X-5) to (28.0cm, 26.5cm) (my ref: B-27) In the GTCO tablet configuration utilities the cursor can paint the test screen area from the lower left corner to about 75% of the test screen area up and to the right. A few years ago we had a problem with the puck: A button wasn't working. We repaired it. The cross-hairs cover fell out and the coil wire broke, we resoldered it. I don't remember clearly but we may have tried to replace some of the coil wire. Questions: How can I repair this here myself? If the coil is not the correct sensitivity will that cause the symptoms we have? What is the correct wire size and number of turns for the coil? Any suggestions on how to rewind it? The felt on the bottom of the puck is worn. Do you have a suggestion for a replacement material? What is a good way to keep the cross-hairs cover from falling out? We are a not-for-profit NGO that works to help rural villagers have good empolyment by making building materials on a small scale. We use AutoCAD to design buildings that use their materials and equipment and tools for them to produce the materials. We also mentor interns from local and foreign universities and colleges. We would appreciate any help you can give us. Sincerely, Geoffrey
Aug 31, 2011 | Summagraphics SummaSketch III Graphic...
Summagraphics SummaSketch III Graphic Tablet Logo
60 people viewed this question
Top Summagraphics Computers & Internet Experts
David Payne
David Payne
Are you a Summagraphics Computer and Internet Expert? Answer questions, earn points and help others
