Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergance ics Can you tell me where to get the instructions. I already ordered the ics. I am having trouble finding the fuses and getting the red hi voltage wires out of the towers. It would be much easier to solder the ics out of the tv and on a bench. thanks for any advice.
  • james dziemianzuk
    james dziemianzuk Dec 18, 2008
    Problem fixed. I replace both ICs and checked fuses. Fuses ok, but ICs must have been bad. I just had to manually adjust the convergence when I was done. I could tell as soon as I turned the tv on after replacing ICs it was fixed. The blue was no where as bad as it was, just a little tweaking in the setup menu. Thanks to all who helped. Now if I could only fix my Dell plasma,
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Convergence Issues... (again)
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Having trouble with red convergence
Your TV has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,
http://servicemanuals.vstore.ca/index.php/cName/convergence-resistors   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
Jan 21, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Red convergence moves up and down on screen
Hope that helps!
Jan 21, 2009 | Philips 55PW9363 55" Rear Projection...
Picture has red color shadow
need new convergence ICs. You can get replacement Ics with free instructions at the following link.
Jan 15, 2009 | Televison & Video
How to replace the converge ic
Your convergence IC's have gone bad. There are 2 of them, you should go ahead and change both while you have it apart..
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may last 2 years, or only last 2 minutes..
Once you remove the old IC's, using a solder ****** (radio shack will have this as well...) test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been very HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
Hope that helps!
Jan 12, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence Adjustment
you need new convergence ICs let me know if you want the link to where you can get new ICs along with free installation instructions and instant messaging tech support for free to do the repairs.Thats a free service for customers who buy the ICs
Apr 04, 2008 | Sharp 55R-WP4H 55" Rear Projection...
Toshiba 50HX70 Convergence reset
You will need to replace the convergence ICs. You can order them at this link and they provide free support as well as installation instructions with pics so you can do the repairs yourself. You will need to replace both convergence ICs
Mar 30, 2008 | Toshiba 50H72 50" Rear Projection...
ICS
Replace convergence IC's & check fuse devices....
Normally done by a skilled Sony tech.....
If you need step-by-step instructions, try to find a local tech
who will work with you....please comment....T.
Nov 04, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
